You should upgrade or use an
alternative browser .
Graphics Card (or drivers) issue. ATI 4870
Eye know, eye know
What he means is have you tested your memory using memtest86+? You very well could have some bad memory sticks.
I thought it was obvious what I meant
i7 3770K HT ON 4.7GHz
P8Z68 Deluxe Gen 3
8GB G.Skill Ripjaws X 2133mhz
X-FI Forte + ATH-AD900
1920*1200 / 1920x1080
Corsair AX1200W
Lian Li PC-V1020A
Laptop Specs:
Clevo Sager P170HM //
17.3 Matte 1920x1200 //
i7 2720QM // 8GB 1333mhz //
Dedicated GTX 485M //
Samsung Story 2TB USB 3.0
Hehe
D:D
Intel D975XBX2
ATI Radeon HD 4890 (1GHz)
hp w2207h (22" widescreen)
1680 x 1050
Antec Neo HE 550
Antec P182
Zalman CNPS9500 AT
Logitech MX Revolution
Logitech Wireless Wave
I have now noticed what appears to be a common thread. It seems that nearly every time UAC engages (or even when I attempt to run something as administrator) I am sent directly to black screen (and my keyboard shuts down). What exactly is engaging with UAC that could cause this?
CyberPower PC / Custom to spec
Intel Core2 Quad Q9550 @ 2.83GHz
Gigabyte GA-EP45T-DS3R
4GB OCZ-Gold DDR3 RAM (2x2GB sticks)
Sapphire HD4873 w/512MB GDDR5
Realtek HD (Onboard)
Dell 2408WFP (dvi to hdmi)
1920x1200
Western Digital Raptor WD1500HLFS - SATAII - 150GB @ 10,000rpm
Seagate ST3750630AS - 750GB @ 7,200rpm
Corsair CMPSU-650TX 650w
Coolermaster Cosmos
Water Cooling (CPU) several fans
Logitech MX Laser
Saitek Eclipse II
10MBs
I have no idea. You keep mentioning that keyboard, you sure that thing is functioning right? USB problem - Have you checked device manager for yellow marks next to devices/USB's?
Outside of that, I'm afraid I'm out of ideas.
Sorry.
Intel D975XBX2
1680 x 1050
Antec Neo HE 550
Antec P182
Zalman CNPS9500 AT
I have already tried swapping the usb keyboard for a ps2 keyboard with no change. I only mention the keyboard because it has backlighting and that backlighting goes out each time this occurs. I thought it might provide additional information into solving this problem.
1920x1200
Coolermaster Cosmos
Logitech MX Laser
Saitek Eclipse II
10MBs
Other then reinstalling the OS. I have no other ideas.
Good luck
Intel D975XBX2
1680 x 1050
Antec Neo HE 550
Antec P182
Zalman CNPS9500 AT
I've done that four times. Also doesn't work. Problems begin to crop up as soon as I install the ATI graphics drivers. Someone earlier noted that it is almost definitely not the graphics card or drivers.
1920x1200
Coolermaster Cosmos
Logitech MX Laser
Saitek Eclipse II
10MBs
OK. 10 consecutive runs of Memtest86+ - all passes. Nothing wrong with the memory. What's left? The power supply - the mobo? Could they be bad from the start and if so - how would I know?
1920x1200
Coolermaster Cosmos
Logitech MX Laser
Saitek Eclipse II
10MBs
