GeForce 8800GT ? failure
Re: GeForce GTX 295 ? failure
+1 for GPU-Z :
techPowerUp! :: Downloads
It's free and can log your temps.
Maybe you should check your event viewer logs to see if something else is causing the driver to crash.
(Start>type : Event Viewer > Custom Views > Administrative Events)
Look for a common 'Faulting Module Path' in the application Crash and see if it points to a particular file , usually a .dll or .exe
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Thanks and sorry to be dense but I have installed the Everest software and can see the main CPU temperature 32C but I cant see the graphics card temp.
OK I got the techpowerup and it shows GPU temp 57C PCB temp 44C then GPU 49.8 and PCB 44.5 does that make sense. Couldn't see any particular file implicated in event viewer.
50c is pretty good idle. ;)
now stress it graphically (a good test is 3dmark06) & try to recreate the error, you say you've never touched the fanspeed so leave that stock.....
do you ever hear the 8800 fan speeding up..???
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    8GB 1066mhz buffalo firestix
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    Arctic cooler pro 775
    logitech cordless optical
    logitech EX110
    2mb
Yes ran the test and it failed (twice) "3DDevice9::present failed device lost (D3DERR_DEVICELOST) and the message as before "Display Driver nvlddmkm stopped responding ans was successfully recovered." but no crash. Temp went up to 67 - 52, 52 - 51. I never noticed the fan speeding up. What now? Thanks for the help.
J
73c on the GPU is warm, but not dangerously so.
That DD3DERR_DEVICELOST looks like it may be a DirectX error.
Just a thought, but have you tried downloading the latest DirectX 9.0c redistributable?
Download details: DirectX Redist (August 2009)
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
I have to admit, I'm running out of ideas myself :huh:
Have you had any re-occurrence of 'artifacts' ?
If not, I still suspect a software issue, rather than a h/ware one. As to what it is...
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
Nothing so far except when stress tested! I tried my MS Flight Sim with no issues on highest graphics settings. I've also upgraded the driver to the latest one - let's see what happens. I might be back...
Thanks again
one more thing goto your bios advanced settings , look up pci/e frequency , if its set to "auto" set it manaully to 100 , and the same if its any setting other than 100
the driver fail message plagued vista users for many months on its release and some still have issues with it , its just a case of covering all the bases making sure everything is as it should be
it seems it has reverted back to yuor original problem , the bluescreens you were encountering are due to the same error , vista will try for a set ammount of time (i forget but its in milliseconds) to reset your driver on a serious fault if it cant it will blue screen giving you your "timeout" message
your vista is up to date yes?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
Thanks - I'll give that a go. Today the system rebooted 3 times when idle. Each time the system blamed the video driver (even with different drivers installed). Is it starting to look like a hardware issue? Would it all get better if I just put a new card in? Which one would you recommend for about £60 -£70?
dude you cant replace a GTX 295 with a 70 quid card!!??
    XFX 780i
    OCZ Modstream 700w
    Titan Fenir
    Logitech G5 Gamer
    Razer Reclusa
    8mb
title updated......:)
    ME.....
    Q9450 @ 3.6ghz
    P5K PREMIUM
    HD 5970
    20'' syncmaster
    XCILIO 850w
    unknown ATX
    logitech EX110
    2mb
amd
nvidia
not high end cards, but better than you have got :)
    Acer 5735z Laptop
    2.0 ghz intel pentium dual-core processor t4200 800mhz fsb
    Acer CathedralPeak Rev
    4gb
    Integrated Intel Graphics Media Accelerator 4500
    Realtek
    15.6" HD CineCrystal LCD
    1366x768
    160gb stock drive. ATA
    Stock Notebook
    Stock
    Synaptics TouchPad
    PS/2
    No idea
Hope this makes sense. This only started when TuneUp utilities advised me that I should change the resolution of my display to Max. (1280x1024) from 1280x960. No problems before, then all this stuff. I've gone back to 1280x960 and (so far) no failures. ?Possible cause?
Archie- I looked for pci/e in the setup but it does no seem to be there on my DEll xps 420.
Also I do not have Vista sp2 installed - Tried it then had to go back as my internet wouldn't work!
