Explorer problem on start and context menus and long starting programs
Neophile:
I've lost track a bit.
What type of install media do you have, at what SP level and is your current install at a
higher SP level than that?
And, is simply doing a fresh install out of the question?
Ardneh
    Compaq/SR5130NX
    AMD AthlonTM 64x2 3800+
    NVIDIA GeForce 6150 SE
Ardneh, it's OK thank you.
I have Vista Ultimate SP2 on a stand alone PC. The SP1 and SP2 have been added after installation. I usually clear installation files and I do not have a restore point of before any more. So to follow the http://www.vistax64.com/tutorials/88236-repair-install-vista.html you recommended I'll have to slipstream the SPs, and anyway, as it is useful to have a DVD with them slipstreamed I would take the opportunity to do it.
Simply doing a fresh installation is what I am trying to avoid.
    Home assembled
    AMD Athlon 64 II X3 440
    M4A785TD-V EVO
    Kingston kit 4GB DDR3 1333MHz (KVR1333D3N9K2/4)
    EAX 300-SE X/TD/128M
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Seagate Barracuda ST3120022A ATA Western Digital Caviar Black WD1002FAEX SATAIII Western Digital WD800BB ATA
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
Hello,
I have done slipstreaming before for XP, but I couldn’t do this one for the reason I mentioned. I believe it could help because I fixed a couple of problems with earlier versions of Windows, as far as 95. But with the internet updates it never worked again.
This problem is very annoying because keeps me waiting for the computer on nearly all that is related with the explorer. However, it does not affect the computer or the work in any other way. I am not going to do a clean OS setup now because Windows 7 will be released on October 20th, so I wait a little less than two months and do the installation only once.
Even if the issue was not fixed, I thank you for the good will on the help I received.
    Home assembled
    M4A785TD-V EVO
    Realtek (On board)
    Dell 15FS-EN
    1024x768
    Standard
    Standard
    Logitech v550 Nano
    Safeway SW-20-P
    24 Mbs
    PCI ATA-133 Adapter
