Error: Display driver has stopped working and has recovered successfully.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Do you have the latest drivers from nvidia site.
GeForce Release 178
Of course. I installed it after I cleaned the old drivers with driver sweeper in Vista and Driver Cleaner Pro in XP 32bit (I have dual boot).
Right now I installed the Beta drivers offered in 3DGuru on my XP partition and some of the issues like graphic tearing up in Counter Strike Source are gone but this driver is not working well in Vista 64 for me. (don't worry, I downloaded the corresponding driver for my OS).
    Intel E8500 C2D
    Gigabyte EX38-DS4
    2x2GB Corsair 4 4 4 12
    Palit Radeon HD4870 1GB
    RealTek
    Philips 20.1
    1600x1200
    WD 500GB ABYS
    ThermalTek 750W
    CoolMaster 690
    Zalman 9500CnPU
    Logitec
    Logitec
    1.5Mb
So am I the only one to encounter this issue?
    Intel E8500 C2D
    Gigabyte EX38-DS4
    RealTek
    Philips 20.1
    1600x1200
    WD 500GB ABYS
    ThermalTek 750W
    CoolMaster 690
    Zalman 9500CnPU
    Logitec
    Logitec
    1.5Mb
No I have had this error when playing Oblivion like 2 months ago.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
    Intel E8500 C2D
    Gigabyte EX38-DS4
    RealTek
    Philips 20.1
    1600x1200
    WD 500GB ABYS
    ThermalTek 750W
    CoolMaster 690
    Zalman 9500CnPU
    Logitec
    Logitec
    1.5Mb
Installing the current drivers that were out at the time. But that isn't working for you.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
Now I get this error randomly. I don't even have to use a special program!!
WTF?!
I always downloaded the drivers from Nvidia web site. The recent driver is: 178.24 for the 9xxx series.
My GPU is made by Gigabyte, so I went into Gigabyte website and I see that the recent driver is: 175.16.
Gigabyte is not following the updates by Nvidia?
Do you think that that might cause the problem I'm experiencing? Could it be that Gigabyte didn't release the updated driver since it causing problem with their manufactured GPU?
I hope installing the driver from Gigabyte web site will fix this issue.
    Intel E8500 C2D
    Gigabyte EX38-DS4
    RealTek
    Philips 20.1
    1600x1200
    WD 500GB ABYS
    ThermalTek 750W
    CoolMaster 690
    Zalman 9500CnPU
    Logitec
    Logitec
    1.5Mb
Gil80, again, this may not be your solution, it seems that it was mine though since I haven't had the issue since I did it.
I have an Acer AL2216W, for this particular model, Acer does not offer a Vista x64 driver. Now, they also have another similar model to mine, the Acer AL2216WD, this one has a x64 driver and apparently, the only difference is that the latter one has DVI options and mine doesn't it.
Since I have nothing to loose, I went ahead and tried it and I have been error free for more than a week now (where's that damn wood when you need it! ;)).
I don't know if you are going to be as lucky as I am and find a similar situation with your LCD but it is worth a try I think.
Good luck.
    Intel Q9650 w/CM V8 Cooler...
    EVGA GTX260
    Realtek High Def Onboard
    Acer 22" LCD Widescreen
    1680 x 1050
    Thermaltake Speedo Advance
    Air Cooled... See CPU
    Logitech G7
    Logitech G15
    Comcast 6MB Broadband
    Linksys WRT54G router
I got this a lot when playing Second Life, but if I install a graphics driver while in safe mode, I'll never get it.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
just a suggestion,
try disabling User Account Control, some nVidia drivers for the latest cards conflict randomly with vista UAC. Its an imbecile solution to an imbecile problem but it worked for me. I guess it's a vista problem since i tested 3 nvidia cards (Quadrofx 5600, Geforce 8800 ultra, Ceforce 8800 gts) an i got consistent results before and after disabling uac.
Anyway I can play smoothly now.
I'm having the problem something like this too. but i do not play games. the problem is when i watch DVDs with either WMP or PowerDVD.. the blue screen appears and restarted.. i've tried upgrading to the new driver version also.. but still giving me problem.. anybody have any idea please share with me..
i'm using Vista ultimate x64
nvidia 8500GT 512mb
    Pentium 4 3.0 GHZ L2 cache
    ASUS P5LD2 SE
    3GB
    Nvidia 8500GT 512MB
    Samsung SyncMaster 793MG
    1024*768
    80GB - Windows XP 80GB - Windows Vista Ultimate x64 160GB Backup Files and others
    CoolerMaster Centurion
    Microsoft
    Microsoft
    TM net 1MB
