error code BIOHD-8 and BSOD crashes help
Yes, use EaseUD Partition. When it opens, it should find both hard drives. Does it? For the problem drive, does it show the partition with your personal files?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
On EaseUS partition it shows my new current drive and another that says unallocated space with the total capacity of my old hard drive. When I go to Disk Management on my computer it shows the partitions on this new computer and it says 'Disk 0' new to the partitions. For my old hdd it says 'Disk 5' and it shows all the partitions and the capacity space on each one but it's not accessable. On the "File System' category it says 'RAW' for the partitions on my old hdd while on the new one it says "NTFS'. When I click on them it only tells me I need to format the disk before i can use it but I don't wont to format it cause I know it will erase my data.
Also I found this link that points to other apps that can recover data from bad sectors.
http://forums.techarena.in/hardware-peripherals/1092536.htm
    HP Pavilion Slimline s3500f desktop pc
    AMD Athlon 64 X2 5400+ 2.8 Ghz Dual Core Processor
    M2N61-AR rev.1.2 Asus
    4GB DDR2 SDRAM
    Integrated Nvidia Geforce 6150SE nforce 430 L2 Cache 1.0MB
    Integrated Realtek ALC888S 6 channel HD Audio
    VGA and DVI widescreen LCD Monitor
    640 x 480 - 60Hz
    500GB Serial ATA-300 3.5" 7200.0 rpm model:ST3500620AS SuperMulti 16X DVD(+/-)R/RW 12X RAM (+/-) R DL LightScribe SATA drive model:ATAPI DVD A DH16A6L
    160W
    Slimline
    Amatech Copper Base/Aluminum Heat Sink & 2.75" Fan 4-pin con
    HP PS/2 optical mouse
    HP PS/2 multimedia keyboard
    Cable High-Speed Broadband
In EaseUS, it should show two disks- Note that my disks are both installed using SATA cables to the mobo.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Would you recommend I download Teamviewer and you can try and have a look at it yourself?
    4GB DDR2 SDRAM
    640 x 480 - 60Hz
    160W
    Slimline
I think EaseUS is the app you want. We just have to find your old drive.
Perhaps you can provide a screenshot of what it shows.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
yes thats how it looks on EaseUS but the Disk 6 says Unallocated. I am tempted to use this 'Spinrite' app that is mentioned on the above thread. Seems to be the right cure for my problem.
    4GB DDR2 SDRAM
    640 x 480 - 60Hz
    160W
    Slimline
I need a reference. Please provide a screenshot.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
How? With Prt Scr?
    4GB DDR2 SDRAM
    640 x 480 - 60Hz
    160W
    Slimline
With the desired screen showing, go to Startup\Programs\Accessories and find the Snipping Tool. Launch it. you're screen will blur.
Click in a corner of the screen you want to make a screenshot of, and while holding the button down, outline the entire screen. When you release the button, a new screen showing the screenshot outlined in red will appear. Select file, save as. give it a name and save it. Upload it here using the attachment (paperclip) feature.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Thanks for the instructions. I also found it while searching the windows help menu. I used the windows snip method though.
    4GB DDR2 SDRAM
    640 x 480 - 60Hz
    160W
    Slimline
When you click on Disc 6, you can try the Check Partition or the Explore Partition. If that doesn't help, you can click on the Wizard and try to recover the partition. With such a large primary drive, I'm surprised you don't have it partitioned. If you did, you could try to copy the partition before you tried to recover it.
If I understand it correctly, you can't boot from that drive. You could try to repair the mbr from within EaseUse Partition. I'm assuming there's a problem with the mbr.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Well when I did the HD Diagnostic from my hard drive's manufacturer it told me I had bad sectors which is what caused my old computer not to boot windows cause the sectors it needed to read from to boot may be damaged. I have read that thread from the link I just posted and I'm more convinced now that Spinrite is the program that will get me pass through this mess. I'm going to find out more about it.
    4GB DDR2 SDRAM
    640 x 480 - 60Hz
    160W
    Slimline
Good luck to you. I'm afraid I've gone as far as I can go with you.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
I believe I have had this error code for a year, maybe more.
Not too sure of the symptoms of a BIOHD-8 error on the HP self tests, seems like my programs were just hanging up and the odd system crash. Thats one of the main reasons I bought a SSD hard drive, its much quicker on bootup, restarts and certain other programs like CCleaner. Its been probably more like 2 years I've had this error code.
    HP a6745f
    AMD Athlon X2 5050e 2.6GHz 2-Core AM2/AM2+
    MSI - MS-7548 (Aspen) Chipset: AMD 780G
    DDR2 - PC2-6400 (800 MHz) with 4GB
    NVIDIA GeFroce GTX 650
    stock
    LG 27" LCD
    I dont know
    Stock WD 320GB 7200rpm 120GB Patriot Blast SSD-HD
    Upgraded to 650W from 300W
    stock HP Pavilion
    stock
    Logitech wireless
    Logitech wireless
    got no clue
