GoldenRust
I'm using a Geforce 8500GT, it has a VGA port and a DVI-I port.
My OS is vista home premium 32bit.
I have a VGA monitor (my first monitor)
I have a second monitor that has a DVI-I port and a VGA port.
When I try to use my second monitor via enabling extended desktop in the windows dialogue box, the screen remains blank. I can move my mouse over to the screen though, although I cannot see it.
If I look at the NVIDIA control panel it says that the second monitor is using a VGA connection, when in fact I want it to sue a DVI connection (It's connected using a DVI-I dual link cable.)
_________________________________________
I've tried only using the second monitor as my primary monitor, I can see the screen when the bois loads up (there's DVI written text on the screen) but as it gets to the windows login screen, it goes blank and says no signal.
How do I fix this?
How do I fix this?
