dvd rw cd drive
Take a screenshot, paste it into an imaging program, MS paint will do, then use tinypic.com to create a link to it. Paste the link into your reply
    AMD Turion(tm) 64 X2 Mobile Technology TL-58 1.90 GHZ
    2.00GB
    NVIDIA GeForce 8400M GS
    Conexant High Definition SmartAudio 221
    Generic PnP monitor
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
hope this is what you need?
All I can tell you guys is to try them in another machine. If you feel up to it, you could also try a Repair Install. The tutorial is written with Windows 7 in mind, but it also applies to Vista.
Repair Install - Windows 7 Forums
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Well i just got windows 7 today, so i am going to install it later, hopefully it will work in windows 7, i really dont want to get a new dvd drive if i can help it
Thanks for trying anyway mate, I put a positive note to your reputation
    2.00GB
    Generic PnP monitor
Thanks man, I got that.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
Tell me, how did you manage to be a Vista Pro, and yet still a Junior Member?
    2.00GB
    Generic PnP monitor
I am active at Sevenforums.com. The admins are the same, and I have my Seven Pro badge there. John gifted me here because the tech support for Vista and Seven are basically the same.
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
