DVD drive won't recognize a software disk
Which disc do you have, Hyperfont, Auto Punch ....?
That software is not cheap from what I can see.
Well at least you have found some support, I'm sorry we couldn't be more help.
Let us know how it goes, we don't like to stop trying till it's fixed. :)
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
I don't have any of that, it's just the basic software to run the machine that I can't get installed
OK, I am curious if the flash drive method would work, it sure seems odd that your DVD drive doesn't even know there is a disc in it, it should at least say something like unable to read or something.
    Asrock P67 Extreme4
    auria eq2367
Vista Home Premium 64 bit
Re: DVD drive won't recognize a software disk
Well, I have some news.
I got in touch with the company that I bought the machine from and they gave me an 800 number for Singer Education support.
After talking with them, it seems that my drive speed might be the problem. Once I fax them over a copy of my receipt, they will send me a new disk that will hopefully be compatible with my drive speed.
In the meantime, as soon as I can locate my flash drive, I'm going to try to copy the files to that in hopes that I can install it from there.
Funny thing, I have a WD external hard drive and I tried to copy the files to that but my desktop computer won't recognize that it's attached.
Another can of worms that I don't care to open.
Thanks everyone.
Try this
Go to search by the start button. Type device manager.
Look for any yellow markers by the drivers. Maybe a driver is corrupted.
If the software company does not come through, we can check to make sure drivers are updated. That may be a problem, too.
Sorry my earlier suggestions did not work out. I do wish you luck, though
Ok at this point I'd just try restarting both your computers and see if that doesn't clear up any issues, both with the DVD and can't recognize hard drive problem. Also, make sure you're connecting the external HD to one of the USB hubs in the back of the machine, and not through a monitor or keyboard port, or even ones on the front of your machine. And not through a USB splitter. I've had recognition issues with those in the past. Also make sure your other computer will recognize it like normal to make sure it's not your HD's fault.
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
Richard, I've already done that a number of times and there were no problems that I could see.
I had to send my computer in for some warranty work and they replaced my hard drive, my wireless module and they also replaced my CD/DVD drive. It's a newer model, so I'm thinking that it's also a faster one.
I'm going to see if my daughter can come over later with her laptop and maybe I can copy the files to and from that, and then maybe install the software.
Let us know how it goes.
    Asrock P67 Extreme4
    auria eq2367
Wish you luck with whatever you decide.
I have this happen sometimes and a reboot fixes it
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Check Autoplay is not set to do nothing when an .exe is inserted
Change it to show files
    LENOVO 64734VM
    15 inch
