Drivers & Hardware
I would try the system restore. Go to the Acer Management software at the top of your screen then restore to factory specs. As well the info for the restore should be in the manual. Otherwise yes return it to the store and hopefully they can exchange it for you. As well try looking into if they do an exchange to pay the difference for the 6920 it really rocks. HD screen and has a lot more power.
Otherwise yes its best to go to the store ask for an exchange. Even if you want them to fix it they will probably do the same thing return it to factory specs. So SAVE anything you need to ok? Good luck.
If you need any other help my email is
Thats what I did to my 7520. Worked really well. After your restore remember to download all available updates. Service pack 1 really makes vista stable after you get it.
very informative sir...this is my first OS shift from 32 bit to 64 bit. I found this furom very helpful
    E7300
    EMX P43
    4 Gig Kingston DDR2 800
    ATI 4670
    Viewsonic VG1930wm
    Seagate 250Gig
Great. Welcome to 64 bit. It rocks. Heck I have Diablo II and a heck load of older games playing fine in it. New games all seem fine so far.....havent had too many problems. Sometimes strangely enough, I have to turn off the sidebar to get a game to play. For instance Diablo II actually doesnt run properly with sidebar on. Other than that excellent seems to emulate 32bit fine for stuff that needs it. Make sure when you use antivirus that it will run in 64bit. I used windows live one care here because I wanted to make sure it would run fine in it. 64bit vista is getting more support all the time and it runs much faster. Nice to meet you.
This thread contains information on running System Information and Assessment tools and also provides links to the latest official manufacturer Drivers and Software provided for your computer including the place for your System Support.
You should always have the latest Official Drivers for the best Performance, Security, Compatibility & Bug-Fixes for your Hardware, Software and Operating System.
Devices Identification and System Information
VistaForums SysInfo Utility
Designed to help you find Information about your system and enable other users to identify problems and help you quicker!
http://www.vistax64.com/tutorials/176785-vistaforums-sysinfo-tool.html
GPU-Z
Graphics Card utility designed to give you all information about your video card and GPU.
GPU-Z Video card GPU Information Utility
CPU-Z
System information tool for Microsoft Windows that detects the CPU, RAM, Motherboard Chipset and other hardware features used in your computer.
CPUID
System Requirements Lab
Looks at your computer's hardware and software to determine whether or not your current system can run a product. Each of your computer's components is evaluated to see how well it meets the minimum and recommended requirements. Recommendations are made on how to update or upgrade each component which does not meet the listed requirements. Sometimes, a simple, free software download is all that is needed.
Can You Run It? Powered by System Requirements Lab
Vista has two built-in System Information & Analysis Tools
Hardware & System Information
Click the Start-Menu and type msinfo32
Windows System Assessment Tool
Click the Start-Menu and cut/paste the link into the searchbox and run:
winsat formal -v -xml %userprofile%\Desktop\WinSATResults.xml
System Manufacturer websites for Drivers and System Support:
2WIRE - Drivers, Software, Support & Documentation
3COM - Drivers, Software, Support & Documentation
ACER - Drivers, Software, Support & Documentation
AMD GAME - Drivers, Software, Support & Documentation
ASUS - Drivers, Software, Support & Documentation
ATI/AMD - Drivers, Software, Support & Documentation
BROADCOM - Drivers, Software, Support & Documentation
BROTHER - Drivers, Software, Support & Documentation
CANON - Drivers, Software, Support & Documentation
CONEXANT - Drivers, Software, Support & Documentation
CREATIVE - Drivers, Software, Support & Documentation
DELL - Drivers, Software, Support & Documentation
Download details: DirectX WebSetup Update (Online Installer)
Download details: DirectX Standalone Update (Offline Installer)
DLINK - Drivers, Software, Support & Documentation
Epson - Drivers, Software Support & Documentation
FUJITSU - Drivers, Software, Support & Documentation
GATEWAY - Drivers, Software, Support & Documentation
GIGABYTE - Drivers, Software, Support & Documentation
HP - Drivers, Software, Support & Documentation
IBM - Drivers, Software, Support & Documentation
INNO3D - Drivers, Software, Support & Documentation
INTEL - Drivers, Software, Support & Documentation
KODAK - Drivers, Software, Support & Documentation
LaptopVideo2Go NVIDIA Laptops - Drivers, Software, Support & Documentation
LG - Drivers, Software, Support & Documentation
LINKSYS - Drivers, Software, Support & Documentation
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Micorosft - Mouse and Keyboard Drivers, Software, Support & Documentation
NETGEAR - Drivers, Software, Support & Documentation
NVIDIA Drivers, Software, Support & Documentation
PANASONIC - Drivers, Software, Support & Documentation
REALTEK - Drivers & Software, Support & Documentation
S3 - Drivers, Software, Support & Documentation
Saitek - Drivers, Software, Support & Documentation
SAMSUNG - Drivers, Software, Support & Documentation
SANDISK - Drivers, Software, Support & Documentation
SiS - Drivers, Software, Support & Documentation
Synaptics - Drivers, Software, Support & Documentation
TOSHIBA - Drivers, Software, Support & Documentation
TRIDENT - Drivers, Software, Support & Documentation
Trust - Home
VIA - Drivers, Software, Support & Documentation
VIEWSONIC - Drivers, Software, Support & Documentation
WESTERN DIGITAL - Drivers, Software, Support & Documentation
Where is apple dirver?
I cant see an apple driver. I would guess its a part of Apple Quicktime Possibly. Reinstall Quicktime. I cant see any driver for apple on here.
Quicktime is installed as any other app, drivers are mainly hardware related.
If you install any software that has driver type libraries then that driver will be in the install.
Apple - QuickTime - Download
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
No guff drivers are hardware related. Thanks Captain Obvious. Apple related drivers are something different though. I think reinstalling quicktime as previously listed would solve the problem. I would try that. If that doesnt work I am not quite sure. Thanks for the link to quicktime for the person with the problem that is a help.
We werent talking about a gateway. You are mistaken. I didnt mention a gateway once. I dont think the person I was talking to (Which wouldnt be you) was mentioning a gateway difficulty either.
Hi everyone!
I want to ask a question about Windows XP.
Sorry,but i don't know where to ask, and I found this site with Google.
So:
I re-installed Windows(those fu**ing viruses...) and then, the Windows install said
"The Windows Installer cannot copy the file 'CNBJMON.DLL'." Abort/Retry/Ignore
I clicked several times on Retry, but it failed, so I clicked Ignore.
The Windows correctly installed...at least it looked like.
And now what do I find?
Well, I cannot play video/sound files.
In fact, i don't hear any sounds...
And, my old games also cannot start.:(
PLEASE help!!!
It's urgent!!!
