Driver_IRQL_not_less_or_equal: 0x000000D1
Hi Mate.
Thanks for the information - I've tried to do what you have suggested me and I get an error :(
Follow the suggestions given here. You are having similar problem i believe.
    Wipro
    Intel dq35j0
    8 Gb
    inter express chipset
    Realtek
    Wipro
    1024*768
    500 gb
    Dell
    DELL
    100 mbps(office lan)
The BSOD reports the same driver as being the issue.
Are you having any problems connecting to the web? How do you connect to the web? If you're using wireless, try disabling the wired connection (first try in Windows, then try in the BIOS).
Then I'd suggest trying another network card - they're pretty cheap (around $15 at WalMart/BestBuy) - or even cheaper online. (the current one will have to be disabled in the BIOS when doing this).
Uhm... maybe once every 2 weeks I can't connect to the internet, and to fix it, I just do a repair in the Local Area Network... and i'm connected through the modem Ethernet.
If it's a network card that' the issue, I'll switch it, but as mentioned in my other posts mate, I am getting a "Kernel_Stack_Inpage_Error" blue screen :(
