DreamScene Enhanced by DeskScapes
How to Enhance Windows Vista DreamScene with Stardock DeskScapes
Stardock DeskScapes extends Windows DreamScene to support dynamic animated wallpaper by adding support for the new .Dream format. The .Dream format supports triggers, dynamic content, MPEG video, WMV video, and author information. This gives you a wider choice of animated wallpapers to choose from.
For more information and updates, see: Stardock.com: DeskScapes
DeskScapes is only for Vista Ultimate, and you must have Windows DreamScene installed. See: How to Install and Use DreamScene in Vista
On some computers, DeskScapes and can cause a significant performance impact. Some Dreams will use more of the CPU Usage than others. You can check in Task Manager (CTRL+SHIFT+ESC) under the Performance tab to see how much CPU Usage is being used by a particular Dream.
  • If the DeskScapes Dream background goes blank on you, then select a regular Windows Wallpaper and then select the DeskScapes Animated Wallpaper again. (EX: after a bad shutdown or returning to desktop from a game) See: How to Change the Desktop Background Wallpaper in Vista
  • You can download free .Dream files from here: WinCustomize.com: Dream. Just save them in the location below to be able to select them as DeskScapes Animated Wallpapers.
  • You can use the free program DreammMaker to create you own dreams. See: http://dream.wincustomize.com/dreammaker.aspx?c=1
  • Dream files are stored at: C:\Users\(your username)\Documents\Stardock\Dreams
PROBLEM TROUBLESHOOTING:
EXAMPLE: Stardock DeskScapes Progam Interface
NOTE:
You can see this by clicking on the DreamScapes shortcut in the Start Menu or the C:\Program Files (x86)\Stardock\Object Desktop\DeskScapes\DreamTasks.exe file above.
ATEP ONE
How to Install DeskScapes
2. Download and install the free version of DeskScapes for Vista Ultimate.​
NOTE: If you would like to make your own DeskScapes Dream files, then download and install the DreamMaker program. See: WinCustomize: DreamMaker Download
STEP TWO
How to Change a DeskScapes Desktop Background
1. Open the DreamScapes program interface and choose an option.​
NOTE: See example above.​
A) Go to step 2.​
OR
1. Right click on a empty area of your desktop and click Personalize. (See screenshot below)​
NOTE:
A) Pause DreamScene - This will pause a Windows DreamScene and DreamScape desktop background.
B) Play DreamScene - This will unpause the Dreamscene from above to allow it to play again.​
2. Click on Desktop Background. (See screenshot below)​
3. Click on the Picture Location drop down list, and then click on DeskScape Animated Wallpapers. (See screenshot below)​
NOTE:
For Windows DreamScene Content, see: How to Install and Use DreamScene in Vista
B) You can edit this Picture Location list from within the registry location of:​
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Wallpapers\Images
4. Select a DreamScene (DeskScapes Dream file) you want on your desktop background. (See screenshot below).​
NOTE: Just hover your pointer over the DreamScene to see a prevew of it on your desktop without it being selected.​
5. Click OK to select the highlighted DreamScene.​
NOTE: You can download more free .Dream files from WinCustomize.com: Dream
Just save them in this location below to be able to select them as DeskScape Animated Wallpapers. (C:\Users\(User Name)\Documents\Stardock\Dreams)
LOL, you're welcome CoccoMeister. Glad you have it sorted.
    Home made
    AMD Athlon X2 6000+
    ASRock ALiveXfire-eSATA2
    2x2GiB DDR2 PC2-6400
    GeCube ATI Radeon HD3870 512MiB GDDR4
    Built in HD Audio, digital output
    Samsung SyncMaster 206BW, SyncMaster 940B
    1680x1050 + 1280x1024
    WDC 250GB SATA + lots of externals. :)
    Antec Earthwatts 500W
    Antec Sonata III
    Air
    Logitech G9
    Logitech G15 (1st edition w blue lightning)
    DL/UL: 50/10Mbit
