Double trouble with my Vista
SFC told me there are some corrupted files unable to fix, BUT I cannot access my CBS logs.
Access is denied.
What to do?
    DELL XPS M1710
    Intel Dual Core 2.0GHZ T7200
    4GB DDR2
    nVIDIA GeForce Go 7900GS 256MB
    17" DELL, 17" ASUS
    250GB HDD
First read the info I sent, above about svchost..
Yeap, I've done that, and I took out some of them, for example the UPnP service. Should I take out the TrkWks that they describe inside?
As I mentioned before, after I took them out, ran CCleaner, MalwareBytes and arrange my startup config, it runs faster.
    DELL XPS M1710
    4GB DDR2
    17" DELL, 17" ASUS
    250GB HDD
The problem that bugs me most is this
Why now? I had it the same for two years, why all of a sudden now when nothing hasn't changed for at least two weeks?
    DELL XPS M1710
    4GB DDR2
    17" DELL, 17" ASUS
    250GB HDD
Get to safe mode and tell me how computer works.
Tried safe mode yesterday and today before it got smoother, had no problems apart from 15% memory usage and around 10% CPU.
Will try now and come back in a couple of hours, bedtime for me.
    DELL XPS M1710
    4GB DDR2
    17" DELL, 17" ASUS
    250GB HDD
Dont worry so much about usage, right now I am 20% ram usage.
Just as long as it works properly
Take your time. Read and do as much as you can or want from this tut.
Optimize Windows 7 - Windows 7 Forums
Good for Vista or 7
Go to process explorer. Take a screen shot, so we can see what is eating your RAM.
Using RAM isnt necessarily bad. It just means your computer is working on a lot of things, and not as many things are getting to the page file as before. If you not using much of ur RAM wouldnt it be a waste of money?
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Right things got annoying once more - RAM is once again 50% and CPU now goes often to 100%.
I noticed one thing - it happens around 10 seconds after I enter Vista, so it has to be something that goes after this time, something that starts up.
I ran a System Health diagnostic last night and for 60 seconds, the report pointed out to me that 20% of my CPU is always used by DCOM Launch and Plug and Play. How do I deal with them? They are the main part of the svchost that eat up the energy.
I'm doing the Process Explorer now.
    DELL XPS M1710
    4GB DDR2
    17" DELL, 17" ASUS
    250GB HDD
I noticed it goes very slow after the fans kick in high gear - aka high heat. Checked with SpeedFan, temperature was above 60 degrees when it started.
    DELL XPS M1710
    4GB DDR2
    17" DELL, 17" ASUS
    250GB HDD
Turn off the computer. Boot computer. Tell me exactly what you hear. Long beeps short beeps, 1 beep 3 beep. one long one short etc.
