Does SP1 allow use of 4gb RAM?
Put simply, YES!
SP1 contains a fix which allows the x32 user to ''see'' the full 4gb installed, it cannot change the address space though. so 3.2gb will be your limit!!
GO X64.
:)SK
In the meantime, I have purchased the 2x2GB RAM Modules to exact specifications, and they should be installed by yours truely within the next 48 hours. I will let you know the outcome, in anticipation that this Notebook is still servicable.
Atta boy! :D
Remove the battery before you install the RAM.
Sometimes it won't be readily apparent that both sticks fit. You may find that you have to raise the dimm slots upwards in order to expose and access the second slot underneath the first? No biggie, there isn't much pressure holding them down, so gentle fingertips will suffice to lift them up. If this isn't the case for you, even better.
G'Day Fumz and skunk "butter-knives" smash.
Mission accomplished....4GB [3.2GB] installed on 32Bit SP1 today!
System information;
My sincere thanks to Fumz and skunk 'butter-knives" smash for your encouragement, patience and ever helpful advice throughout this exercise.
The self-confidence, though increased immensely, will remain in check while more understanding and knowledge is gained.
Cheers.
sassofalco.:D
    nVidia GeForce Go 7300, 128MB
    1280x800x60Hertz [max.]
