Pooch I ve tryed everything you said, and everything is in order, no problems. Any other suggestions?
Try these ideas after each one test if the ports are working.
1. Try uninstalling every usb device and then restarting the computer. You might be asked by windows to restart the computer again do as it asks. The ports will be automatically reinstalled.
2. Try reinstalling your chipset driver. If you dont have a cd with drivers then try the manufacturers website or ask.
3. Go to C:\Windows\System32\DriverStore\FileRepository\usbstor_xxxx. Copy usbstor.inf usbstor.PNF USBSTOR.SYS and paste them into the C:\Windows\INF folder. select Copy and Replace, if asked. Reboot and try your ports.
4. Go to device manager and disable the standard enh.anced pci-usb host controller Check your ports Dont forget to re-enable if it doesn't work
5. If you have Daemontools orAlcohol installed try uninstalling them.
If the ports are still not working you will most probably have to reinstall Vista as this could be the result of a bad update.
I hope this little list helps
Pooch
- Self build
- Phenom II x4 Black Edition 940-Arctic-Cooling Freezer Xtreme
- Asus M3A32-MVP Deluxe
- 8 gig Samsung PC800 RAM
- NVidia 9600gt
- AD1988b
- 22" TFT-MONITOR WIDESCREEN mit VGA/DVI 17" Video7 TFT
- 1680 : 1050 1280 : 1024
- Drive #1 - SAMSUNG HD252HJ (250 GB) Drive #2 - Hitachi HDT721010SLA360 (1000 GB) Drive #3 - SAMSUNG HD250HJ (250 GB) Drive #4 - SAMSUNG HD103UJ (1000 GB) External eSATA
- PSU
- Thermaltake Toughpower Cable Management 750W
- Case
- Enermax Chakra
- Cooling
- 2x 120mm Front and Back 1x 250mm Side
- Easy Line Laser Mouse
- Standard
- Other Info
- I have also used Fedora, Suse, Ubuntu Linux And all other Windows from 95 to date except ME
