"display driver atikmdag stopped responding and has successfully recovered" error
That's disappointing :(
A few more ideas:
You do have Vista updated to at least SP1?
You aren't overclocking the CPU by any chance?
What PSU are you using? You might double check that all cables/plugs are firmly secured to the video card.
Are you launching crysis with the x32 or x64 .exe? Whichever one your using, try using the other.
Have you tried temporarily downclocking the card yet? It may worthwhile as a test.
To rule out RAM being an issue, it may also be worthwhile running memtest86+ overnight to see if it throws up any errors at you:
Memtest86+ - Advanced Memory Diagnostic Tool
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
Try making a shortcut from the folder to the desktop and launch from there.
    Self Build
    QX9650 (black box) 3.0GHz@3.9GHz
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
my vista is updated with service pack 2.
i don't overclock my CPU.
i don't want to downclocking the card... if it doesn't work in his original clocks, so i need to replace my card.
it's not only a problem in crysis... it's just happened to me with the new game-Prototype.
(crashing to desktop with the warning message...)
i think that the cables are firmly secured to the video card... because i didn't touched it since i got this computer, and in the beginning i didn't had this problem (i played Assassin's Creed and GTA IV just fine.)
what exactly i need to do with memtest86+? i never used it.
thanks for your help :)
With memtest86+, download the iso, burn it to a disc or flash drive and when you boot it will automatically run.
It's a looping program of several tests. It will run indefinitely until you end it. One or two passes isn't enough to guareentee the RAMS fine so that's why I suggest letting it run over night while you sleep.
If theRAM passes, it will show zero errors. If it fails it will show how many errors. You're aiming for zero.
I only suggest downclocking the card as a test. If it runs fine while downclocked then you know the cards a dud and needs to be replaced. Downclocking is quick and not permanent.
It may also be worthwhile downloading and installing the latest physx package (even though ATI doesn't use it)
NVIDIA PhysX System Software
However the fact that GTA IV and AC ran fine tends to suggest a software issue rather than a h/w one.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
so, what cause this problem?
I assume you've updated your video drivers?
Have you tried temporarily disabling aero, played a game and seen if it still crashes?
I'd explore all software issues first before blaming a faulty card and potentially replacing it needlessly.
Hi GigaDude,
there are plenty of theories and "suggested" solutions on how to solve this problem. Do a Google search on this and you'll come up with hundreds of threads/posts. This error is prevelent with both ATI and Nvidia under Vista.
One of my many posts about this problem here - http://www.vistax64.com/graphic-cards/195706-display-driver-has-stopped-working-saga.html#post901985
There is no one answer, yet plenty of suggestions - which might work for one person, but not the next.
In most instances (me included) people have reported that replacing their video card helped solve the problem.
In my caes, my 3870 was indeed faulty (overheating) and had to be RMA'd.
I personally think "one" of the problems lies with the design of the today’s video cards and the heat generated by them, plus the shoddy fans used, which for the most part don't really do a good job of cooling.
I know a lot of people have complained about the heat generated by today’s video cards from both companies, and I've really head huge complaints about ATI's fan speed and cooling solution, which in the end tends to equate to inadequate cooling or overheating.
That’s why it’s really important to have a case with adequate airflow and cooling. A crowded case generates heat.
Just my two cents.
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
i think it's an hardware problem, i installed the new ATI drivers- 9.6 and it didn't fix the problem. i just experienced a crash in Prototype.
also, the install of physx didn't solve it.
how many clocks i need to down to see if the card is a dud and i need to replace it?
To all of you who are getting this "atikmdag stopped responding and has successfully recovered" error, listen carefully. Before I get to the solution, let me tell you my configuration. ATI Radeon HD3850, 4 gigs of Corsair Ram, Intel Core 2 Duo 3.0 GHz CPU, Windows Vista Ultimate SP2 (32 bit), that's enough for now. I've been getting this error while running my lattice screensaver, and on my Grand Theft Auto games. I've spent 3+ days researching the net and reading thousands of forums on this issue. I tried EVERYTHING software wise such as disabling Windows "AERO", removing that KB952287 hot fix, disabling all anti-virus software, installing that new hotfix from Microsoft, uninstalling / updating video driver, and disabling this and that in Windows. None of these solutions have worked! The problem is the ATI driver, not the video card itself. I went out and bought an NVIDIA 9800 GT made by PNY. ALL PROBLEMS SOLVED!! No Lockups, freezes, error messages. This video card is a good middle of the road card that is somewhat comparable to the ATI HD3850. I didn't want to spend $350+ for high end, so for $119.00 this replaces what I had. ATI needs to get their act together on their driver issue, they've been having this problem for quite some time. Other than that, ATI builds a better quality video card (hardware wise), and produces better image quality. NVIDIA on the other hand, is the opposite. NVIDIA's build / image quality isn't quite as good, however their DRIVERS are far more compatible and stable over a wider range of games and apps OVERALL. If it weren't for this, I would have stayed with ATI, as I have been with them for many years. For those of you who are having this problem with NVIDIA, I'm surprised! Try updating your drivers & make sure that your video card is compatible with whatever game(s) you're having the issue on. One more thing, I've been running Vista Ultimate for 14 months now, and I've had very few problems, if that, very stable & reliable.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
lol, I've seen plenty of "nvlddmkm.sys has stopped working" errors with nvidia cards ;)
Each company sometimes release good drivers, okay drivers and woeful drivers.
    P8Z68 Deluxe Gen 3
    Corsair AX1200W
    Lian Li PC-V1020A
I fought this problem for two weeks on my Vista Home Premium 64-bit. I kept downloading ATI older drivers until I stumbled on to this one:
"8-12_vista64_dd_ccc_wdm_enu_72276.exe" and it worked for me.
I would download the newer updates and they still caused the same error. The latest version "9-6_vista64_win7_64" released in June finally works without the errors.
I can't say this will work for anyone else as there have been numerous "fixes" that don't work for everyone. Having used ATI cards for years, I'm disappointed in the way AMD hasn't responded to this error that have caused so much consternation among ATI card owners. I just spent $200+ for this card in December so I really didn't want to trash it for a new one quite yet.
Hope this helps someone.
    Personal build
    Intel Core 2 Duo E8500 Wolfdale 3.16GHz
    Intel DP35DP
    8GB
    Radeon HD 4870 512MB
    Samsung 2433BWX 24" Widescreen.
    1920x1200
    1. WD10EADS 1TB used as External with eSATA 2. WD5001AALS 500GB 3. WD5001AALS 500GB 4. WD640AALS 640GB
    PC Power & Cooling Silencer PPCS500 500W
    COOLER MASTER Centurion 534
    PSU, Graphics card, plus 4 120mm fans
    See above.
    Logitech S520 Keyboard and Mouse
    AT&T DSL---Elite, I think it's called. :-)
    LITE-ON Black 22X SATA 22X DVD Burner with LightScribe Logitech S-220 17 Watts 2.1 Multimedia Speaker System
for me the problems disappeared from 9.2 onwards. i have a 3870x2 and had problems till that driver. been fine ever since :)
    intel core 2 quad Q9450
    gigabyte EP45-DQ6
    8gb Gskill PC6400
    Visiontek Radeon 4870x2 2GB
    X-FI fatality FPS 7.1
    Viewsonic VG2230wm
    1680X1050
    VelociRaptor WD1500HLFS 150GB 10000 RPM, WD CAVIAR black 750GB
    Antec TruePower New TP-750 watt
    Cooler Master HAF932
    XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
    comcast 16mb\second
