DEP - Enable or Disable
How to Enable or Disable DEP in Vista, Windows 7, and Windows 8
Data Execution Prevention (DEP) is a security feature that can help prevent damage to your computer from viruses and other security threats. Harmful programs can try to attack Windows by attempting to run (also known as execute) code from system memory (RAM) locations reserved only for Windows and other authorized programs. These types of attacks can harm your programs and files. If DEP notices a program on your computer using memory incorrectly, it closes the program and notifies you with the DEP stop error. DEP is ran in a software mode and in a hardware mode. If your processor supports DEP (NX for AMD, and XD for Intel), then you will have hardware and software DEP. If it doesn't, then Vista will just use software DEP. 64 bit applications will have DEP enabled all the time by default, but 32 bit applications do not and must have DEP manually enabled for them. For more information, see: Windows Help and Support: Data Execution Prevention: FAQs
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.
Do not disable DEP, or exclude (OptOut) a program, unless you have adequate protection and are having problems only with a known safe program that DEP will not let run and you cannot live without it. Remember DEP stopped the program for a reason. Either it is just a improperly running program, or some sort of malware trying to get into restricted memory.
Adequate Protection:
  • Antivirus program with realtime scanning (EX: Avast or AVG are good ones)
  • A spyware/adware program with realtime scanning (EX: Windows Defender, Spybot Search and Destroy)
  • Enable Vista's UAC (User Account Control). It asks you for permission first for anything that wants to run with full access to the computer.
EXAMPLE: DEP Enabled and Disable
NOTE:
DEP is enabled by default. If you installed Enhanced Mitigation Experience Toolkit (EMET), then it will be used by Windows instead of DEP and gray out the DEP settings like below.
OPTION ONE
To Enable or Disable DEP in Vista
NOTE: If you have a 64-bit CPU, then you may also have a no exectute option in BIOS that is the built in DEP on the CPU.
2. To Enable DEP
A) In the elevated command prompt, type in bold below and press Enter. (See screenshot below)​
NOTE: If for some reason this command does not enable DEP after restarting the computer, then use the bcdedit.exe /set {current} nx AlwaysOn command instead.​
bcdedit.exe /set {current} nx OptIn
B) You should get a success message back​
C) Close the elevated command prompt.​
D) Restart the computer to apply.​
3. To Disable DEP
A) In the command prompt, type in bold belowand press Enter. (See screenshot below)
bcdedit.exe /set {current} nx AlwaysOff
B) You should get a success message back.​
C) Close the command prompt.​
4. To Verify the Status of DEP
A) In the command prompt, type in bold below and press Enter. (See screenshot below table)​
wmic OS Get DataExecutionPrevention_SupportPolicy
B) You will get a number (see table below) that will tell you the status of DEP.​
C) Close command prompt when done.​
2 is the default setting.
[TABLE=class:-grid,-width:-500][TR][TD]
Number
[/TD]
[TD]
Description
[/TD]
[TD]
Status
[/TD][/TR]
[TR][TD]
[/TD]
[TD]
AlwaysOff
[/TD]
[TD]
DEP is disabled for all processes. (Step 3 above)
[/TD][/TR]
[TR][TD]
1
[/TD]
[TD]
AlwaysOn
[/TD]
[TD]
DEP is enabled for all processes. (Note under step 2)
[/TD][/TR]
[TR][TD]
2
[/TD]
[TD]
OptIn
[/TD]
[TD]
DEP is enabled for only Windows system components and services have DEP applied. Default setting. (Step 2 above)
[/TD][/TR]
[TR][TD]
3
[/TD]
[TD]
OptOut
[/TD]
[TD]
DEP is enabled for all processes. Administrators can manually create a list of specific applications which do not have DEP applied. (How to Turn DEP On or Off for a Program)
[/TD][/TR][/TABLE]
OPTION TWO
Enable or Disable DEP in Internet Explorer
NOTE: This will be for the 32 bit version of Internet Explorer.
  • For a 32 bit Vista version: C:\Program Files\Internet Explorer\iexplore.exe
  • For a 64 bit Vista version: C:\Program Files (x86)\Internet Explorer\iexplore.exe
Some Active X Internet Explorer add-ons may not work with DEP on. It can cause them to crash and prevent the startup of IE by DEP closing it. If this happens to you, then see: How to Fix a Crashing Internet Explorer in Vista or disable DEP again.
1. Open the Start Menu.​
2. Click on All Programs and right click on Internet Explorer, then click Run as administrator.​
NOTE: If you cannot get IE7 to open using step 2, then click on All Programs and Accessories. Next, right click on Internet Explorer (No Add-ons) and click on Run as administrator instead.​
WARNING: If you do not use Run as administrator, the Enable memory protection to help mitigate online attacks option will be grayed out in steps 5 and 6 below, and you will not be able to enable or disable it.​
3. In Internet Explorer, click on Tools and Internet Options.​
4. Click on the Advanced tab. (See screenshot below)​
5. To Enable DEP for the 32 bit Internet Explorer
A) Under Security, check Enable memory protection to help mitigate online attacks.​
B) Go to step 7.​
6. To Disable DEP for the 32 bit Internet Explorer
A) Under Security, uncheck Enable memory protection to help mitigate online attacks.​
7. Click on OK to apply.​
LOL, I would not say smart, just years of trial and error. Mostly erros until I figured it out. ;)
Help ! Thanks (in advance) for all the expert help here. I had/have a problem with IE7 crashing any time I close a window or tab, so decided to disable DEP via the command prompt route. Now though things have got even worse and windows refuses to start :cry:
The initial screen offers me "Launch Startup Repair" or "Start Windows Normally". The former just doesn't get anywhere - i.e. it looks to fail doing whatever it's trying to within one second. And the latter goes through the motions and then brings me back to the same screen.
I also tried safe mode but that won't start...
Help...I appear to have killed my machine!
Alas, it's a Dell, so I don't have the full retail version Vista DVD, indeed not even a backup that I know where it is....
Can I reverse the bcpedit.exe command from this screen somewhere?
thanks again
Mark
I had this same problem trying to fix a Firefox DEP error. Once I turned it off my system would not start. I was able to resolve the issue by downloading the Vista recovery disk from here http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
and then running it until I got to the place that allowed me to access the cmd prompt. Then using the following command
bcdedit.exe /set {default} nx OptIn
You can't use {current} because you are in the recovery mode, which is not your default boot option. Anyway, it may be too late to help you, but I thought I post it here in hopes it will help someone else. (Spent two hours troubleshooting before I figured it out)
Hi, i have Vista Ultimate x64 , works everything fine, but yesterday with no reason every program works with internet freeze when try to connect, after close of the program system show in status bar information about DEP.
Firefox stuck with empty window, NOD32 antivirus cant connect for updates (cant use sockets) and QIP too (socket problem)
Windows updates works fine
Unfortunately i don´t have restore point...
No virus, checked by antivirus and manualy in proceses, registry and services too.
please help :confused:
Sorry my English
Hello HawkST, and welcome to Vista Forums.
You might also run a thorough spyware scan using something like the free Spybot Search & Destroy to see if it can find anything to.
The home of Spybot-S&D!
What is the message that you get from DEP? Is it the blocked message?
Does everything work when DEP is disabled? If so, you can try adding each program to the DEP exception list (step 7 below) as a test to see if it will work, or step 6 below other than disabling DEP completely.
http://www.vistax64.com/tutorials/65790-dep-turn-off-programs.html
I get blocked message from DEP.
No spyware, malware or virus (Spybot and other antispyware tested)
Everything works, just only programs which try to connect freeze or show error message(connection problem)- after close WIN error message followed by DEP message about block. (IE7 too)
Also I tried add programs to exception list (no effect) and firefox can´t add.
And disable in bios, or "bcdedit /set {current} nx AlwaysOff" not work too.
I´m so desperate...
Hello HawkST,
Did you restart the computer after running the command bcdedit.exe /set {current} nx AlwaysOff in a elevated (Run as administrator) command prompt?
Try using the command bcdedit.exe /set nx AlwaysOff instead to disable DEP to see if it works better for you.
DEP status is Disabled, but still not working. vista updates are latest and sys are checked by scandisk , registry cleaned (after errors) and useless programs uninstaled.
I Tried prehaps everything, from reconnecting lan cable, diagnostic network and finaly reinstall drivers of lan card.
And now I will have to reinstall Win, probably, right?
I'm sorry to say that it sure looks that way. Something has gotten pretty corrupted. :(
I hope the reinstall goes smoothly for you.
Hi Shawn,
Gone through your DEP tutorial which had given me enough information.
Recently installed CRM-Siebel software in to my laptop which is using Windows Vista Home Premium Service Pack 1.
Intially I have installed Siebel version 8.0 , after realizing that vista supports from version 8.0.0.3 ,had applied a patch of version 8.0.0.4.
when trying to login in to Siebel Application DEP is closing IE. After going through your DEP Enable or Disable tutorial , tried to diable DEP always off and other options and tried to access Siebel application but a pop up window is getting by showing IE has stopped working.Could you please suggest any possible solution to avoid this problem and how to go about this.
Please let me know if any inputs required from my end.
Thank you,
Suha
Hello Suha, and welcome to Vista Forums.
It's sounds like Siebel may have installed a bad IE7 add-on causing it to crash. This tutorial below will help show you how to test to see if that is the case and how to remove (disable) the add-on or reset IE7.
http://www.vistax64.com/tutorials/114310-internet-explorer-reset.html
Hi Shawn,
As you suggested enabled add ons which are disabled before,reset the IE by following the given url.Still the problem persist,
A window popup comes by showing IE has stopped working close program.
Please suggest is there any chance of online help.
Thank You,
Suha
Suha,
Since Siebel seems to be the cause of this, try uninstalling it completely to see if IE7 will work afterwards. If it does, then try reinstalling the correct version of Seibel for Vista to see if IE7 then continues to work. If not, then you can try doing a System Restore using a restore point dated when IE7 was working.
As a test, you might also check to see if Firefox can run with Siebel installed until IE7 is fixed.
Hi Shawn,
Here I need to clear that Iam facing the specified problem with IE only when I am trying to login to siebel client application but not with siebel tools and other sites like google ,yahoo etc.
After confirming with Oracle support team applied the siebel patch (8.0.0.5) which is compatable with vista.
Thank you for your continuous support.
Anytime Suha. I'm happy to hear that the newer patch sorted your problem.
Hi Shawn,
Have downloaded the patch from oracle site.I need to work on this ,could you please suggest how can i solve this problem.
Thank you,
Suha
Suha,
It seems to be some specific issue with the Oracle Siebel client application part of the program that will need to be handled through Oracle's support to see what it may be. I am not familiar with this program to be able to offer anything specific relating to it.
I wish that I could help further with this. Please let us know if you find the cause of the problem.
Sorry, :(
