I hope this will help out in clearing the doubt about the deleting of files in the D Drive :
1. Open Windows and log into an account with administrative rights (the account used to setup the computer will work).
2. Right-click Start and select Explore All Users.
3. Before you can remove the backup files and folders, set Windows to view hidden system files as follows:
a. From the explorer window press the Alt key to view the file menu.
b. Click Tools, and then select Folder Options.
c. Select the View tab.
d. Select Show hidden files and folders, remove the selection from Hide protected operating system files and then click OK.
4. From the Folder Options window in explorer, double-click Recovery (D
5. In Recovery (D
find a folder with the same name as the computer name . For example if the computer name is Pavilion_PC-PC, the folder that contains the backup files would be named Pavilion_PC-PC.
6. Select the folder that contains the name of the computer. Do not select any other folder or files. Only select the folder containing the backup files.
For example, if the computer name is Pavilion123, select the folder named Pavilion123.
7. With the folder selected, press Shift + Delete.
8. A Windows opens stating "You don't currently have permission to access this folder" opens. Click Continue.
9. Several confirmation windows open. Click Continue, and Yes until the folder is deleted.
10. Set Windows Folder Options back to their original setting as follows:
a. From the explorer window press Alt to view the file menu.
c. Select do not show hidden files and folders and select Hide protected operating system files.
d. Click OK.
11. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device other than Recovery.
