Ok this is really annoying me now...
i wish I had have read this stuff before!!
ive recently upgraded to vista 64 from xp pro. At the same time, I got a new HDD, some more RAM and a new soundcard... an X-Fi extreme gamer fatality pro. I use it with 7.1 cambridge/creative speakers.
I am now regretting that choice.. for 2 days, I have stuffed around trying to get the damn thing to work.
First off, it installed OK. But, sound was only coming out of the front 3 speakers. It registered that I wanted 7.1, but all the sound came from the front.
So i figured it must be a driver problem.
Every time I try install the new driver, it does not seem to install to the right place - in that once installed, vista decides to tell me that it has found new hardware and automatically starts installing new drivers for it - the old ones. or even worse, now it is stuck there with a big yellow ! ....
I have tried dozens of different ways to get this thing to work. I have deleted everything with 'created' in it more than a dozen times, and still, the same problems keep coming back.
Ive only had the sound card for a few days - so i am planning on taking it back to the shop if i cant get it to work by monday... and change it for something.. but what?
anyone got any suggestions on wtf i am doing wrong?
im running intel cor duo 2 2.66g
6g ram
750gb hdd
nvidia 9800gx2
cheers
mick
EDIT. ive got it back to life - a bit. I've installed a newer driver.. 2.18.6 which is a beta. on the speaker tests through speaker wizard, the majority of sound comes from the front 3 speakers, while random sounds come from the others.
Also, when using conrol panel / sound / playback / speakers, the chime noise comes from each of my speakers EXCEPT the front centre - which seems to play most of the noise for the other test. It also plays the subwoofer vibration correctly.
At a loss for what to do now....
EDIT 2: (if anyones out there?) I have sucessfully upgraded all my Creative software and now, 2 out of the 4 tests play side left/right and rear/left right sounds properly - the other two do not. the ones that play side left and side right do not play front centre. the other 2 still play all sounds out of the front 3. no idea.
