hello iam hoping some body can help
i have reloaded window last night every think has gone fine and the computer is just as fast as it use to be BUT i have updated my wei and it came back with 5.9 for every think but the cpu which use to be 5.9 but now is 5.4
i then installed cool and quit of the asus driver disc to find that it says it is runing 1300 and not 2600 which is what the cpu is
but if you go into the bios it says it is runing 2600 and the clock timing is set to auto
i have manualy put in 2600 in on the seting but cool and quite still see it as runing 1300
like ive said the system does not sem and slower but i would like to now what is wrong
i have update the bios and the cool and quite to the lateist one
thank you
thank you
- home built
- Intel Core i7 920 2.66ghz @ 3.67ghz 1.3v
- ASUS P6T Deluxe V2 iX58
- 6GB (3x2GB) Corsair Dominator DDR3 1600MHz@1400mhz 8-8-8-24
- BFG GTX 285 OCX
- on board
- samsung t220 sync master
- 1680x1050
- 1TB samsung
- PSU
- Corsair HX1000W
- Case
- antec 902
- Cooling
- Zalman CNPS10X Extreme Ultra Quiet x3 120mm + 200mm fans
- Microsoft Wireless Laser Desktop 7000
- 6mb
- Other Info
- LG dvd-rw, LG GGC-H20L blueray player, Sony 2.1 speakers system, HP photosmart c5180 All-in-one Printer/Scanner/Copier (network conected) NetGear DG834G v4 ADSL Modem/Router (Ethernet) netgear GS608 8 port switch WEI Score: 5.9
