wow.. thats a lot of stuff said.
Ya I think you've possibly hit a wall John. but what you should do. is stay at 3.2 GHz and just be happy with that. you can try for a little more of you'd like. but it will be high volts. I just managed to hiot 3.66 GHz and I'm running 1.4875, so I'm still under 1.5v and thats where I wanna be. anything under that. I'm only at this speed for a few benchies and then I'm back to my usual 3.4 GHz. Thats a good even spot for me I'd decided.
You should stay at 3.2 but crank it up to 1.6v and mess around. see how things go. just to see if you can get past that wall, or hole. but then go back to stock settings.
and If i didn't mention it. I did the pencil vdroop mod. and I'm not stable at 3.4 GHz with only 1.425v and before I had to use 1.4725 thats not bad personally. you might wanna give that a try if you dare. I think it's a good idea. that might get you down a few. allow you to go to 3.33 GHz at the same voltage your at now. Just a thought.
oh and I've posted this on this site a few times. and in my sig. but tonight I jsut completed my most recent OC to 3.66 GHz I talked about above. Here's my Mark06 Scores. I'm exited.
http://tinyurl.com/3DMark06 lol
- Q9650 E0 4.0 GHz @1.304v
- eVGA 750i FTW
- 2x2GB Corsair Dominator PC2-8500C5D
- eVGA/MSI GTX 260 SLI
- X-Fi XtremeGamer
- Samsung T240 & 226BW
- 1920x1200 & 1680x1050
- Seagate Cuda 500GB 32mb Cache SATA 7200.(11) + 500GB Seagate Cuda External eSATA, USB, FW400
- PSU
- PC P&C 750w Silencer PSU
- Case
- CoolerMaster HAF 932 (Water-Cooled)
- Cooling
- Plenty of Fans, and a few 230mm Fans
- Logitech MX-518
- Logitech G11
- Other Info
- ASUS 20x Optical, Bose Companion 3, ATH-AD500 Cans :), Patriot Xporter 16GB Flash Drive (Very Fast), & Sandisk Micro 8GB. Nikon D40 DSLR with 18-105mm VR & 55-200mm VR
