Solved Could not load or run (file) pop up window at boot up...NEED HELP TO REMOVE PLEASE!
Re: Could not load or run (file) pop up window at boot up...NEED HELP TO REMOVE PLEAS
This is my screen for the same key...
Can you just edit it & remove the reference?
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Just as a thought, have you tried un-installing the printer & re-installing it?
    40 Meg
That's what I think.
In that subkey on my system, there's only two lines- default and device.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hmmm...on an unrelated matter, I did uninstall and reinstall the printer in the last couple of weeks. I still get the same error message when I boot. But also, I only have one printer and it will not allow me to set as default (it doesn't have the green check mark next to it when viewing printers). It is hooked up wirelessly if that matters at all...
I just un-installed and re-installed the printer which solved the issue of setting the default printer...
But I still can't edit that registry record, nor can I delete it outright...
If you right click on the Windows subkey and select properties, does the administrator and the system have full control under the permissions? If not, you should change it. If successful, you should be able to delete the offending values. If you're not comfortable with editing the registry, set a system restore point before changing anything.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Hooray!!! That one worked!!! I am without the annoying pop up window now!!! Thanks to everyone who replied to my thread, you have all been a big help!!!
I'm glad it worked.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
