WildEagle
Banned
I had to go back and read the title of this thread about six times and I still don't understand the responses!
Most don't address the theme of this thread at all.
Vista 32 bit and Vista 64 bit are TWO totally different Operating Systems (OS's).
You can't just convert one to the other.
Sounds like you'd have to BUY Vista 64 and install it over Vista 32, obliterating it.
That's just my take on it.
Maybe someone else has a different take.......
Shadow![]()
Wrong, you can't install Vista 64 over the top of a 32bit OS. You have to wipe the boot drive clean using the Vista 64 install disc and then install Vista 64. This is how Microsoft set it up, when going to Vista 64, because in some ways the code base is the same, but for the most part the code base between the two are different.
When buying OEM Vista, you must specify 32bit or 64 bit, there is no 64bit disc you can order if you purchased a 32bit OEM Vista. The retail version of 32bit Vista Ultimate does come with a 64bit install disc, with any other 32bit retail version of Vista, you can either go to the Microsoft website and order the 64bit disc online or call Microsoft to order the 64bit disc if you bought a retail edition of Vista, other than a retail Ultimate Edition. When you order the 64bit install disc if your retail edition did not come with it, Microsoft will want to know what your product key is, and in effect, your retail product is now the 64bit product key. If you still want to use the 32bit install disc on a machine, you must call Microsoft or go to the Microsoft website, and purchase a new product key for the 32bit retail disc.
- Core 2 Duo E6600
- Intel 975XBX2
- 8GB's of DDR2 800
- Radeon 3870X2
- HT Omega Claro
- Viewsonic VG2030wm Widescreen LCD
- 1680X1050
- 120GB 200GB 320GB
- PSU
- ThermalTake Toughpower 700
- Case
- Antec P182
- Cooling
- four 120mm fans
- Microsoft Wireless Intellimous Explorer 2.0
- Microsoft Natural Multimedia Keyboard
- 10MB
- Other Info
- 16X LG DVDROM & LG Dual Layer DVD Burner Logitech X-540 speakers
