Context Menu - Add COPY TO FOLDER and MOVE TO FOLDER
How to Add "Copy To Folder" and "Move To Folder" to the Context Menu in Vista
Copy To Folder allows you to right click on a item and copy it to another location immediately. Move to Folder allows you to right click on a item and move it to another locatation and remove it from it's current location immediately.
This is also under the EDIT menu in a Explorer window. (See Example screenshot below)
EXAMPLE: Default Edit Menu Location:
NOTE: These are the keyboard shortcuts to use the Menu bar location while having the file or folder selected that you want to Copy or Move to another folder.
  • Copy To Folder - Press and hold Alt then press E and F
  • Move To Folder - Press and hold Alt then press E and V
EXAMPLE: Copy To Folder and Move To Folder Added to the Context Menu:
NOTE: Right click on a file or folder to see your new additions. You can see what happens when you click on each one beside the context menu screenshot. You can select a different drive to.
METHOD ONE
Using a REG File Download
1. To Add Copy/Move To Folder
NOTE: You can add one or both of these.​
Add_CopyMove.reg
download
B) Go to step 3.​
2. To Remove Copy/Move To Folder
Remove_CopyMove.reg
download
METHOD TWO
To Do Manually in Registry Editor
1. Open the Start Menu.​
HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers
5. To Add Copy To Folder
A) In the left pane, right click on ContextMenuHandlers and click on New and Key.​
B) Type {C2FBB630-2971-11D1-A18C-00C04FD75D13} and press Enter.​
NOTE: To Remove Copy To Folder - Right click on this key and click on Delete.
6. To Add Move To Folder
B) Type {C2FBB631-2971-11D1-A18C-00C04FD75D13} and press Enter.
NOTE: To Remove Move To Folder - Right click on this key and click on Delete.
7. Close regedit.​
Oh sweet there they are! I forgot I had pressed ALT before when I was trying to add Copy to Folder and Move to Folder in Brink's examples. So anyways Brink they are not there in the Windows explorer window: computer>maker
Thanks Dinesh! Didn't mean to be rude to ya just got carried away a bit!
Hey Dinesh, Brink does not seem to be on right now do you have any idea why I am not seeing those options in the menu bar of windows explorer?
Hi Dragonfly, could you please post a screenshot of windows explorer?
Its alright mate. :)
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
You can use snipping tool to capture images and upload it here.
    Compaq
    15"
    160 GB WDC
There now do you see what I mean? Sorry it took so long I had to figure out your way of doing files.
Who ever isn't sitting back laughing their heads off over this if you could explain to me why I have those options in some menus but not others I would really appreciate it!
Dragonfly Girl, you do not have the Copy/Move To options in the top screenshot because you do not have a file or folder selected in the main Windows Explorer window like you do in the bottom screenshot. ;)
Aha that would explain the whole thing! Thank you Brink sorry for confusing you. Apparently I know what I am talking about but many times no one else does!!:rolleyes:
You were a big help with the menu thingy Dinesh! So glad i found these forums. HP had me wanting to go back to win 98se.
LOL, I'm happy to hear that you got it sorted. :)
Hi, thanks for the info, but this is very clumsy. Looks like win 95! Is there no way of putting nested folders into the "send to" menu and get cascading menus like win 98? You could put in an empty copy of your whole document tree, and find the folder you wanted extremely quickly.
Tony B
    Medion MS7366
    Intel Q6600 2G4Hz
    3G0
    Nvidia 9300GS
    hp w2216
    1T0 ATA 80G0 IDE
    dial up
Hello Tony, and welcome to Vista Forums.
You can add whatever folder you would like to the "Send To" context menu. You will have to add the folder you want to send to though since it will not be expand from that folder to select a subfolder though.
http://www.vistax64.com/tutorials/67599-send-context-menu.html
You're most welcome Ghis. :)
Hello Gene, and welcome to Vista Forums.
Thank you for posting back to confirm. :)
Thank you for your time on this and the other tutorials Brink
Regards
    QuadCore Intel Core i7 920
    Intel X58
    12 GB Corsair XMS3 DDR3-1333 SDRAM
    Sapphire Radeon 4890 1GB xFire
    Xonar HDAV1.3
    Dell 2408WFP
    1920x1600
    2xVelociRaptor 150GB (OS) 1TB WD HDD (Storage)
    Corsair HX1000W
    Antec 1200
    Razer Lachesis
    Razer Lycosa
You're most welcome Lomai. Thank you. :)
I loved this little hack to add those folders. Microsoft had to have preprogrammed the function into Windows for this to work. Why didn't they activate them in the release? There must be others too. What is your source for this information?
One thing though; I'm not sure why you chose to add the IDs to the KeyName. I used the actual names under ContextMenuHandlers and added the IDs to the default keys like the image below:
The only difference appears to be that they show up above the "Send To" menu item like the image below:
Is there a reason I shouldn't do it this way? At least I know what those registry keys are for by looking at them.
    Windows Vista Home Premium SP2, 32-bit
    Retrofitted Refurbished Gateway
    AMD
    ASUS M3A78-EM
    Acer 22-in Flat Screen Monitor
    Logitech M705 Wireless Mouse
    Logitech K350 Wireless Keyboard
Hello Andy,
You could use either way that you like best. I just used the GUIDs in the tutorial since that's how they are referenced by default in the registry. :)
