Confused Ethernet Ports
There are no options to delete the network as Vista only lists connections. Here's what I tried, I bridged the Limited Connectivity on board Ethernet with the USB Primary Connection, and for some reason, I have full connectivity across the bridge. I will try to find out why the Network List Manager refuses to list the pseudo network. Clearly, this is a software glitch, and it occurrs on start up of a corrupted system DLL.
    Custom /Purpose Built
    Intel C2Q 6700, 2.66 GHz
    Intel DP45SG
    Corsair XMS 4GB, Patriot 2GB, ^GB Total
    eVga GeForce 8800GT, 512 MB
    SoundBlaster Audigy SE
    Hanng-G 28"
    1920 X 1200
    6 Drives - Hitachi 320 GB (Programs), WD 250 GB (Photoshop ScratchDisk), Hitachi 500GB (WorkFiles), Hitachi 500GB (WebSites), WD MyBook 500GB Ext (BackUp 1 & 2), WD MyBook 500GB Ext (BackUp 3 & 4)
    Thermaltake PurePower 600 Watts
    Antec 180 Silver
    Zalman Hurricane - All Copper
    MS Wireless Laser 5000 (European)
    7.1 Verizon DSL
    Altec-Lansing VS 4121 Speakers, Xbox360 HD DVD ROM,
Now that your connected type in cmd: netsh lan show interface or ipconfig /all to see if it lists the pseudo interface.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
And the Bridged connection is a 1 Gbps connection, as reported by both the details of the connection and per Task Manager Networking.
    Intel DP45SG
    Hanng-G 28"
    1920 X 1200
    Antec 180 Silver
    7.1 Verizon DSL
It stated "The Wired AutoConfig Service (dot3svc) is not running." What the hell is this?
    Intel DP45SG
    Hanng-G 28"
    1920 X 1200
    Antec 180 Silver
    7.1 Verizon DSL
But, ipconfig /all reported:
Windows IP Configuration
Host Name . . . . . . . . . . . . : TechCentral-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : domain_not_set.invalid
System Quarantine State . . . . . : Not Restricted
Ethernet adapter Network Bridge:
Connection-specific DNS Suffix . : domain_not_set.invalid
Description . . . . . . . . . . . : MAC Bridge Miniport
Physical Address. . . . . . . . . : 02-50-B6-05-10-B7
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Link-local IPv6 Address . . . . . : fe80::78be:2b5e:eb21:cebb%25(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.70(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : Friday, October 02, 2009 12:38:17 AM
Lease Expires . . . . . . . . . . : Saturday, October 03, 2009 12:38:17 AM
Default Gateway . . . . . . . . . : 192.168.1.1
DHCP Server . . . . . . . . . . . : 192.168.1.1
DHCPv6 IAID . . . . . . . . . . . : 419582134
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-12-12-C2-E4-00-1C-C0-8F-96-DB
DNS Servers . . . . . . . . . . . : 192.168.1.1
68.238.64.12
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 5:
Description . . . . . . . . . . . : ASIX AX88772 USB2.0 to Fast Ethernet Adapter #3
Physical Address. . . . . . . . . : 00-50-B6-05-06-5A
Link-local IPv6 Address . . . . . : fe80::41e2:bfdb:5559:7e59%14(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.68(Preferred)
Lease Obtained. . . . . . . . . . : Friday, October 02, 2009 12:21:29 AM
Lease Expires . . . . . . . . . . : Saturday, October 03, 2009 12:21:28 AM
DHCPv6 IAID . . . . . . . . . . . : 335564982
68.238.64.12
Tunnel adapter Local Area Connection* 7:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 02-00-54-55-4E-01
DHCP Enabled. . . . . . . . . . . : No
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e50:e9:112c:3f57:feb9(Preferred)
Link-local IPv6 Address . . . . . : fe80::e9:112c:3f57:feb9%10(Preferred)
Default Gateway . . . . . . . . . : ::
NetBIOS over Tcpip. . . . . . . . : Disabled
Tunnel adapter Local Area Connection* 12:
Media State . . . . . . . . . . . : Media disconnected
Description . . . . . . . . . . . : isatap.domain_not_set.invalid
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
    Intel DP45SG
    Hanng-G 28"
    1920 X 1200
    Antec 180 Silver
    7.1 Verizon DSL
Its exactly what it states. I dont think its set to auto run by default. But its a service that allows network information to be pulled from the system. It's not effecting your connection.
But since your connected through a bridge, into a different connection with a different adapter, it could still be the ethernet port of the main board...
What authentication are you using? MAC, or POP3?
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
What authentication are you using? MAC, or POP3?[/QUOTE]
I'm confused? My eMail is POP3
    Intel DP45SG
    Hanng-G 28"
    1920 X 1200
    Antec 180 Silver
    7.1 Verizon DSL
Problem Resolved. Here's what I had to do. It is a software based issue and it directly related to how Vista connects to your Ethernet card.
(1) I unpluged my computer completely, including the power cord.
(2) I changed my switch from a DLink Gigabit to a 5 Port [w/uplink] Linksys. When I changed switches, I lost all connections, even my USB. All connections were local only and the network was "unidentified"
(3) Using ipconfig /release and ipconfig/renew only caused errors, so I disabled all the ports in the NSC, and then enabled the onboard ethernet card. Connection re-established.
(4) Microsoft must supply all users of Vista with an ability to completely clear the network management cache and the registry of fixed network settings.
Normally, when you change locations, DHCP automatically re-assigns you a new IP and you can continue as usual. But, Vista has such a "strange" security layer that it handles all network connections as being on a private [literally private VPN] network. When my computer was shut down, Vista's security took over and changed all my settings so that my PC looked for a VPN, but none existed. So when I forced it to re-connect to a totally different network, all those old settings had to be replaced.
Here's the new ipconfig /all:
Ethernet adapter LAC-ETH01:
Description . . . . . . . . . . . : Intel(R) 82567LF-2 Gigabit Network Connection
Physical Address. . . . . . . . . : 00-1C-C0-8F-96-DB
Link-local IPv6 Address . . . . . : fe80::c4e1:f0eb:caab:c2bf%16(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.66(Preferred)
Lease Obtained. . . . . . . . . . : Friday, October 02, 2009 3:56:25 AM
Lease Expires . . . . . . . . . . : Saturday, October 03, 2009 3:56:25 AM
DHCPv6 IAID . . . . . . . . . . . : 268442816
68.238.64.12
Tunnel adapter Local Area Connection* 6:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter
IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e50:3c2e:1c5f:3f57:febd(Preferred)
Link-local IPv6 Address . . . . . : fe80::3c2e:1c5f:3f57:febd%10(Preferred)
    Intel DP45SG
    Hanng-G 28"
    1920 X 1200
    Antec 180 Silver
    7.1 Verizon DSL
68.238.64.12
Glad you got it running :) Always something simple, but I was asking what authentication you were using because if it was POP3 then I would suggest the email and/or password you were using to access the internet is incorrect. But obviously you got it. Bookmarking this for reference :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
