Confirmed: Office 2010 will come in 32-bit, 64-bit flavors
Last month, a very believable rumor started flying around in regard to Office 2010 shipping in 32-bit and 64-bit versions. Check out ZDNet and Within Windows to see how the conclusion was drawn. Everything pointed to Microsoft finally offering a 64-bit flavor of its Office suite, previous versions of which have only shipped in 32-bit or 16-bit flavors. In an e-mail exchange with Ars today, a Microsoft spokesperson confirmed that Office 2010 will be available in both flavors: "Yes, Office will have two separate 32-bit and 64-bit versions. Office 2010 will be the first to do this."
Full Story: Confirmed: Office 2010 will come in 32-bit, 64-bit flavors - Ars Technica
Good news for 64 Bit vista users.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Thanks Slimy for the info on the x64 Office news.
    My first build
    Intel E8400 Wolfdale 3.0GHz
    Intel DP35DP
    4GB Kingston ValueRam DDR2 800 (PC2 6400) 1.8v
    MSI NX8400 256MB PCI
    onboard
    HP w2007
    Seagate Barracuda ES.2 250GB SATA 7200 RPM 32MB Cache
    Antec Earthwatts 430 PSU
    Antec Solo Black (VERY quiet)
    Antec Tri-cool 80mm front - stock Antec 120mm rear fan
Thanks, Silmy. Good news. Hopefully lots of others will follow suit.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Thanks Emil,
Perhaps the change to x64 will really take off now that Microsoft's flagship is moving in the right direction.
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
I think it's a bad move. Not everyone know's what 32bit and 64 bit mean. People will get confuzzled and use open office or other program.
    Gateway: GM5472
    AMD Athlon(tm) 64 X2 Dual Core Processor 5000+ (2 CPUs), ~2.
    ATI Radeon HD 3650
    Dynex
    Dynex
Which ones...the people who've been using Office since Office 97, or those that have never used Office to begin with, Which in today's business world is virtually none. Just about any office or admin job in todays job market requires some skill in Microsoft Office. ;)
As to the availability of a 64-bit version, not really sure what to think. Office 2007 works extremely well under Vista x64, so???
    Intel D975XBX2
    ATI Radeon HD 4890 (1GHz)
    hp w2207h (22" widescreen)
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
    Logitech MX Revolution
    Logitech Wireless Wave
Well if both versions come on the same disk, it will be less confusing when buying, as the a user who tries to install 64 bit on their 32 bit OS will just get given a message saying it's incompatible.
I think it's a good idea really to get 64 bit programs rolling out more and let 64 bit really take off.
    Intel Core 2 Quad Q9550
    XFX MB-750I-72P9 NF750i
    4096MB Corsair XMS2 PC-5400
    ASUS Nvidia Geforce GTX470
    ASUS Xonar DX
    1920x1080 & 1680x1050
    Logitech G11 Keyboard
    100Mbps
The thing is with office is that it should be possible to produce an Install DVD with both x86 and x64 versions and an intelligent installer which offers the x64 as the primary option if the system is compatible, with a fall back option of x86 for those who cannot install x64 or have commercial/or other reasons to do so :)
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    Samsung 32" TV
Great idea and completely agree.
    Intel D975XBX2
    1680 x 1050
    Antec Neo HE 550
    Antec P182
    Zalman CNPS9500 AT
I think putting them both on one disk would be good. Then, when you install, it will analyze your system archetecture. If it is x64, then it offers both options, and if it is x86, then it just installs x86.
This will eliminate people not knowing what the difference is.
I am still planning on using OpenOffice though. For $300 for the simplistic version, M$ can live with it.
~Lordbob
    ASUS P5QC
    2x2GB
    NVidia GeForce 9500GT 1Gb
    Mobo
    Samsung SyncMaster 206bw
    Razer Lachesis
    Razer Tarantula
    not fast enough
I believe starting the end of this month they're sending out SP2 for Office 2007. I'm sure I saw it in my RSS Feeds from Mary Foley.
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
    Acer Aspire 5920gmi notebook
    NVIDIA GeForce 8600M GS
    Realtek
    crawl
Putting them both on one disk is not only possible, but probable, at least with OEM versions, Vista OEM (not sure about the retail) comes with not only both architecture flavours, but also with all possible distribution flavours, I.E. Vista home premium x86 right up to Vista Ultimate x64.
Using an "intelligent" (I believe it uses XML) install package,the installer automatically chooses the right architecture for your machine (it can be changed on 64 bit machines to install 32 bit OS). then depending on the key you use during installation, it installs the appropriate version.
Following a logical line of reasoning not only will M$ incorporate both architecture variants on a single disk, it will probably also use an intelligent installer, minimizing confusion for the novice end user, whilst also allowing more experienced users to configure their installs with XML.
M$ can't lose with this kind of forward thinking, making installations easier and less painful benefits everyone, that is, until they move all their software into "the cloud".
    Home Built
    AMD 6000+
    ASUS M3N78-VM
    Kingston 8GB
    NVIDIA 8800GT
    VIA
    CIBOX 22" Flatpanel & Panasonic Viera 42" Plasma
    Maxtor 250GB Samsung 250GB Samsung 320GB
    500W
    XCLIO
    Air / Fan
    Logitech MS Revolution
    Logitech G15
    10MB
all i can say is Its about time. .
    Core 2 Duo 6600
    ASUS P5B Deluxe
    8 GIGS Corsair C4DH
    EVGA 8600 GTS
    Dell P990
    WD 250 G DiamondMax 250 WD 500 x 2 Raid 1
    Antec 650
    Thermaltake Armor Full Tower
    Zalman ZNPS 9700
    Office 2007
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
Any news on when they will release it? Looking forward to the new look.
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
Very Good News
    Athlon 64 X2 4400+
    ASUS M2A VM HDMI
    1+1 GB KINGSTONE 667
    NVIDIA 8500 GT 512 MB
    REALTEK HD
    15" LCD
    1024 x 768
    320 GB SATA II
    LOGITECH
    LOGITECH
    256 KBPS
