Thanks so much but I have to just skip back a step. I just found my VISTA product key on the sticker on top and I am going to have to plug in the new HDD. I rang NEC and it will cost $45 and 2-3wks to get a copy of VISTA OEM disc. Can I download it from somewhere now I have my product key? Or do I boot with Ubuntu disc I made and then download Vista? Or is it better to upgrade to Windows 7??? I'm kinda lost here. Apparently I will need to install drivers and things as well. Sorry I'm such a knuckle-head pain in the bot![]()
Before you download anything, you have to decide do you want Vista or Do you want Seven. You will need the upgrade version of Seven if you decide to go with Seven. The cost of the upgrade in the USA is about $135.00. If it were my computer, and could afford it, I would go with Seven. Vista is really yesterday and Seven is Today. Seven has an easier to use UAC and it has a lot of "eye candy" that you will probably like. Once your computer is ready, download to see if you can handle Seven.
Windows 7 Upgrade Advisor - Download - Microsoft Windows
If you can handle Seven you must decide do you want 32 bit or 64 bit and if you can handle 64 bit.
Why You Should Go 64-Bit With Windows 7
32-bit and 64-bit Windows: frequently asked questions.
When you install Seven or Vista, be sure that you are online. Most of the drivers and things that you need will be downloaded automatically.
You no longer need Ubuntu to install either Seven or Vista.
- Dell XPS420
- 6 gig
- ATI Radeon HD3650 256 MB
- Intergrated 7.1 Channel Audio
- Dell SP2009W 20 inch Flat Panel w Webcam
- 640 gb
- Cooling
- Fan
- Dell USB 4 button optical
- Dell USB
- Other Info
- DSL provided by ATT
