Solved Computer says i have 0 bytes of space left and other things that need to be fixed.
Re: Computer says i have 0 bytes of space left and other things that need to be fixed
I will have to contact Microsoft instead as they brought Mojang.
Microsoft own Mojang but they are still an independent company. So you would probably contact Mojang. Personally I would go on Minecraft support forum. People there should be able to assist you better.
    Alienware Aurora R4
    Intel Core i7 4960x
    Alienware 0FPV4P
    8GB Corsair 2333MHZ
    GTX 760
    Soundblaster Recon 3D PCie
    Dell U2312HM
    1920x1080
    Samsung 840 PRO SSD
    Alienware Aurora R4 ALX
    Alienware Watercooling
    Alienware Tactx Mouse
    Alienware Tactx Keyboard
    162MB DL 12MB UP
OK. Lets get on to the "Stopping services and other weird messages" problem
EDIT: This thread is getting viewed by lots of guests.:huh:
    Old 2003 Medion computer
    See "System Manufacturer/Model Number"
    2.00 GB
    Slooooow.
Hello?
    2.00 GB
    Slooooow.
Start>Run>Type "Services.msc"> have a look for any third party services you have running and "stop" them to see if that fixes the problem (I would recommend one at a time) just make sure you don't disable core operating system services. Screen shots would help, and if you have a lot of programs running disable them from starting up in "msconfig". A lot of the programs you have installed are probably not a priory to be running all the time. Also a please and a thank-you would go a long way.
    Alienware Aurora R4
    Intel Core i7 4960x
    Alienware 0FPV4P
    8GB Corsair 2333MHZ
    GTX 760
    Dell U2312HM
    1920x1080
    Samsung 840 PRO SSD
    162MB DL 12MB UP
All the ones I dont use are already disabled
    2.00 GB
    Slooooow.
Found some werid stuff i will delete
    2.00 GB
    Slooooow.
found some more i will delete...
    2.00 GB
    Slooooow.
OK. Finished doing that. How about the other werid messages like
''Prepering your desktop''
"Stoping Windows Update Service"
''Save\Memory problem. Contact your admin''
These Messages happen when I turn off or on
    2.00 GB
    Slooooow.
Hello?
    2.00 GB
    Slooooow.
Hello,
are the problems solved?
If not I would help you:
1) The preparing your desktop is normal, when you start your computer and it is not a fast one or the system partition is out of space.
How much space do you have left on C:?
2) The Windows update problem could be also connected with the memory problem.
3) Do you have tested your RAM? If it fails, look for some new modules gebrauchte & neue Speicher für Computer Server & Notebooks
Problems solved. It was a virus in a youtube ad
    2.00 GB
    Slooooow.
