Comp not recognizing my graphics card, and a couple other things
I downloaded it from the AMD site, Drivers & Tools | GAME.AMD.COM
And it works fine now.
The only problem is, after installing a bunch of windows updates last night, I am already getting the PXE-E61 "Operating System Not Found" error again, and that was the main reason I had to call Dell yesterday :mad: because I have to manually shutdown and restart my computer about five times to get it to start up.
I used to love Vista but this is really starting to make me mad, because if there's no way to have Vista on this computer without it getting messed up, I'm going to have to downgrade to XP again unless I can get 7 somehow, but I think they already closed the free thing off.
    Dell Studio 17
    4GB DDR2
    ATI HD 3650
    1440 X 900
    250GB SATA, 7200 RPM
    Razer Lachesis
This may be a result of hardware failure/Incorrect BIOS setting:
How do I resolve and PXE-E61 error message and crash?
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive
try:
1.Go to Bios Settings
2.Remove LAN booting from booting options...
3. Check all cables/connections
Boot sequence should be:
DVD/CD drive
flash (FDD)
Any USB device (floppy, external HDD, etc)
HDD
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
When I called Dell we did a hardware check (fn+power button) and nothing came up wrong so I'm pretty sure it's not the hard drive unless it just didn't detect anything for some reason.
It seems to be booting up fine now, it just did it twice when I started it up this morning. But the last couple times I started it up it worked fine. But I'll check the BIOS anyways because if it will eliminate the error altogether than it would be awesome.
*EDIT/update*
I checked the BIOS and the boot order on mine is:
1. HDD
2. USB
3. CD/DVD/CD-R Drive
4. Removable Devices
5. Network
I'm guessing it should go:
1. CD/DVD/CR-R Drive
2. USB
3. Removable Devices
4. HDD
And I should take out Network?
I'm not sure because it's not the same as the ones listed on the link.
    Dell Studio 17
    4GB DDR2
    ATI HD 3650
    1440 X 900
    Razer Lachesis
