Sorry My Bad
Forgot they changed the wording on Windows 7 from Vista - and didn't check on a vista machine
The entry you want in vista is "Manage Network Connections" and not "Change adapter settings" everything else is as before.
You should see an entry for each network "adapter" on the machine, including the bluetooth. As previously stated you may want to disable this if it isn't used, (right click - Disable), if this is not viable then try changing the order as stated above.
Hope this helps
Hope this helps
- Operating System
- Windows 10 Pro x64 Latest Release Preview
- Acer G276HL 27", (DVi) + Samsung 39" HDTV (HDMI)
- 2 x 1920x1080 @50Hz
- Real World Computers (Custom by Me)
- AMD FX8350 Vishera 8 Core @4GHz
- Asus M5A78L-M USB3
- 32GB [4x8GB] DDR3 1600 MHz
- ASUS Xoner DG + SPDIF to 5.1 System + HDMI
- Samsung 32" TV
- 1920 x 1080
- Internal Crucial CT256MX100SSD1 256GB SSD, Seagate ST2000DM001-1CH1 2TB, External (USB3) Seagate Backup+ Hub BK SCSI Disk 8TB 2.5/3.5 Hot Swap Cradle, USB3 + eSata (client HDDs) NAS 4TB
- PSU
- Aerocool Templarius Imperator 750W 80+ Silver
- Case
- AeroCool X-Warrior Red Devil Tower
- Cooling
- Hyper103 CPU, Rear 120mm, Front 2x120mm, Side 2x120mm
- 68 MB Down 18.5 MB Up
- Other Info
- Six Sensor Auto / Manual Digital cooling (Fan) control with Touch control Panel
