Codec Destroyed itself?
I can't find an uninstall button for WMP.
I have more than likely messed up the codec's because of all the packs I DL'ed.
Is there a specific string of names I can follow to remove the codecs?
Such as C: User/Etc./Etc.
I have uninstalled all codec packs but there still seems to be remnants of them when I go to the Add/Remove Prgams page.
Thanks Clevo.
OK... so, the soloution could be that when installing all those codecs and removing them you may have accidently removed the DVD codecs/decoders.
Theoretically, installing WMP should restore those decoders/codecs but it kinda makes sense that it won't install if you don;t have those files ,perhaps those files are installed by the DVD players themselves?
I think the next step is to identify which of those one or two codecs you needs and install only those few that are needed rather than trying a scatter gun approach.
So I should do what then?
It's as clear as mud isn't it? :)
It's all kinda guessing here but... either find a way to re-install Medi Player or install only the missing codecs...
