Quite the BIOS history.
There is a Chipset update as well Global Version 8.3.0.1013
[ 2001 ]
Support new CPUs. Please refer to our website:ASUSTeK Computer Inc.-Support-
[ 1902 ]
Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc.-Support-
[ 1803 ]
1. Fix CPU ratio will not reset after load BIOS default
2. Enable support for N/2 Ratio option
[ 1705 ]
1. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc.-Support-
2. Update LAN BOOTROM to 2.06
[ 1604 ]
1. Enhance memory compatibility under FSB1333 mode
[ 1501 ]
1. Add new CPU uCode to support new processor
[ 1405 ]
1. Update CPU ucode to support new processor
2. Revise SLP 2.0 rule
3. Enable hotplug support under AHCI mode
4. Fix displayed CPU frequency incorrectly after downgrade CPU ratio
[ 1202 ]
1. Fix system may sometimes hang after load default in setup then exiting right away while having Conroe CPU installed.
2. Add new uCode to support new CPU.
[ 1102 ]
**Please update AsusUpdate to V7.09.02 or later prior making this update.**
**This BIOS does not support roll back to earlier BIOS**
1. Finetune Q-Fan control algorithm
2. Enable EIST under VISTA
3. Update CPU Ucode to support new CPU
4. Fix BBS device string not correct under AHCI mode
5. Support SLP2.0 string
6. Fix HCT unreported I/O and memory issuse
7. Support disable USB function item
8. Allow disable XD for conroe L
9. Add full reset after change DRAM mode to enhance memory compatibility
10. Support CONROE E0 CPU(FSB 1333)
11. Fix AC Power loss function not correct
12. Support x4 DIMM
[ 0806 ]
1. Enable support for WiFi-TV card
2. Enable PreslerXE 3.73 support
3. Enable USB like support for SATA HDD connected to JMICRON controller when JMicron option is set to IDE or AHCI mode
4. Drop CPU fan low limit to 600rpm when Conroe CPU is in use.
5. Enhance ATA ODD compatibility
6. Support Conroe-L CPU
7. Fix CPU VCORE too high after overclocking fail
[ 0701 ]
2. Fix DRAM frequency incorrectly display problem under auto, standard and AI N.O.S mode
3. Reduce system full reset of times
4. Patch some VGA card can't found when NB Vcore value has been set too high
5. Fix DDR frequency 889 unstable by SPD
6. Add new CPU Ucode to support Kentsfield B3 stepping CPU
7. Improve S3 resume time
8. Fix FSB not correct displayed in BIOS setup when CPU has been set to non-standard frequency
9. Fix chassis fan 2 speed not correct when fan speed too low
[ 0509 ]
1. Support DDR2 double side x16 module
2. Enable support for CPU ratio adjustment on Kentsfield B0 stepping CPU
3. Enable conroe/kentsfield ratio overclocking higher above default value
4. Fix CPU Fan profile mode not correct after system shotdown
5. Revise temperature reading algorithm
6. Update MRC code
7. Enhance memory compatibility for DDR533 and DDR667 modules.
8. Revise S3 fuction not stable when CPU FSB over 300MHz.
9. Add dram frequency help string
[ 0309 ]
1. Fix SATA configuration select disable and compatible mode will show SATA3 and SATA4
2. Show some memory spd items to improve overclocking ability.
3. Enhance overclock capability above FSB 500
4. Support jumperfree FSB to 650
5. Add auto calculate DDR frequency rule to display DRAM frequency
6. Support Conroe CPU ratio adjustment
7. Fix system fail to POST after crash free or EZFlash when using particular XE CPU. (Note: System will still boot after performing clear CMOS)
8. Fix some ODDs fail to read files from CD under EZFlash2
9. Enhance performance with NVDIA VGA cards
10. Support AiGear for Presler 3200 c1 stepping CPU
11. Revise NOS table for conroe B2 stepping
12. Support FSB533 CPU over 3.4GHz frequency under AIbooster
13. Fix AI Gear fan speed too low sometimes under normal mode
[ 0211 ]
1. Improve Conroe 2.93 cpu overclocking ability.
2. Patch CPU count not correct issue.
3. Fix ez-flash2 crashfree function may fail issue
4. Modify the VID value to max when Ai Gear enable
5. Fix VID too low under Ai Gear level1 2, and 3
6. Add New CPU Ucode to support new CPUs
- Custom - Built Myself
- E8400 Core 2 Duo @ 9 X 400
- ASUS P5E3 Deluxe WiFi X38
- 4GB OCZ Platinum OCZ3P13332GK
- Gigabyte Radeon HD RX3850 775MHZ 512MB 1.4GHZ GDDR3
- On Board
- Dell SP2208WFP
- 1680 X 1050
- 1 X 640GB 7200 Western Digital 2 X 500GB 7200 Seagate Barracuda All with cooling fans
- PSU
- ENERMAX 1000W Galaxy DXX
- Case
- CoolerMaster CM690
- Cooling
- Zalman CNPS9700 NT / 4 X 120mm / 1 X 80mm Case Fans
- Microsoft Comfort Optical 3000
- Microsoft Natural Ergonomic Comfort 4000
- 10mbps down / 1mbps up - Shaw Xtreme
- Other Info
- Lg GGC-H20L BLU-RAY HD-DVD Reader BD-ROM DVD+-RW 16X8X6 DL 4X Scythe Multi-Format Card Reader / Floppy Drive
