Can't Connect to Wired Network!! Please Help!!
Adapter
43 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
44 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
47 ...00 00 00 00 00 00 00 e0 isatap.{9D397A0D-2664-4586-BED7-E30045A0BCAF}
69 ...00 00 00 00 00 00 00 e0 isatap.{B3292D8D-3F32-4FF2-8E3D-66065E47F28A}
48 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
49 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
70 ...00 00 00 00 00 00 00 e0 isatap.{C2F3624C-8546-4342-97DC-B2A80035C599}
57 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
65 ...00 00 00 00 00 00 00 e0 6TO4 Adapter
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.123.254 192.168.123.187 276
127.0.0.0 255.0.0.0 On-link 127.0.0.1 306
127.0.0.1 255.255.255.255 On-link 127.0.0.1 306
127.255.255.255 255.255.255.255 On-link 127.0.0.1 306
192.168.123.0 255.255.255.0 On-link 192.168.123.187 276
192.168.123.187 255.255.255.255 On-link 192.168.123.187 276
192.168.123.255 255.255.255.255 On-link 192.168.123.187 276
224.0.0.0 240.0.0.0 On-link 127.0.0.1 306
224.0.0.0 240.0.0.0 On-link 192.168.123.187 276
255.255.255.255 255.255.255.255 On-link 127.0.0.1 306
255.255.255.255 255.255.255.255 On-link 192.168.123.187 276
Persistent Routes:
Network Address Netmask Gateway Address Metric
0.0.0.0 0.0.0.0 192.168.123.254 Default
IPv6 Route Table
Active Routes:
If Metric Network Destination Gateway
1 306 ::1/128 On-link
8 276 fe80::/64 On-link
8 276 fe80::a97d:7b17:a6d0:ec2f/128
On-link
1 306 ff00::/8 On-link
8 276 ff00::/8 On-link
Persistent Routes:
None
Years later, same problem. I have three computers all using the same wireless LAN. Two networks are visible, one being just a D-Link range extender. Two computers still work fine on either network.
One, the Vista laptop, has recently decided to not get beyond "Identifying... (Public network)". It sees the two networks, and says it gives local access, but it will not give internet access on either.
I have downloaded a new LAN driver, uninstalled the driver to revert to factory settings, checked the registry settings, turned stuff on and off. No dice.
I started the process described on page of one of this thread, but when I input "ROUTE -f" ( or ROUTE-f or ROUTE - f) in command prompt, I get a lecture about what prompts mean, and I don't know enough to use that information.
Is anyone still using Vista who might have a suggestion?
Good grief. It had nothing to do with the laptop. The router needed to be rebooted.
