Can not get graphics card to work- help
Ok, I did what you said and it worked great. I guess i bought a new video card for nothing. Thumbs up to XFX, Ive been throwing this card around the last few days, not really taking much care with it, yet it still works.
Anyone want to buy a used video card? I dont suppose its worth much, I guess I can keep it around for a spare.
thanks for all the help. if i have any problems with the new ATI card, ill be back....
    ZT Systems 7308Ma
    AMD Phenom™ II X4 920 Quad-Core Processor
    ASUS M3A78-EM
    6GB DDR2 Memory
    Integrated ATI Radeon™ HD 3200 GPU
    Realtek® ALC1200 8 -Channel High Definition Audio CODEC
    HANNS-G 19" and SONY 17"
    1280 by 1024
    WD 750GB SATA SeaGate 200GB SATA Maxtor 80GB IDE
    ATX 12V 300W
    Blu-Ray BD/DVDRW Combo Drive SATA TSST corp CD/DVDW Combo Drive
I went to download the nvidia driver for the 8600gt for vista 64 and save it before i try this and i find it rather incredible that its a 116MB download! doesnt that seem extremely huge for a driver download?
No, probably has the program to run the card and do tweeks, etc. Sounds like you are going in the right direction. If windows does not detect new hardware then something is up. Looks like you are on the right track for that 'something!' Glad it worked out.
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    Hitachi something or other 500 gigs
    650 watts
Actually, I never got a windows detected new hardware message on reboot. but it works none the less
    ZT Systems 7308Ma
    ASUS M3A78-EM
    6GB DDR2 Memory
    1280 by 1024
    ATX 12V 300W
Very odd indeed. But yes, it works and that is all that matters in the end! :D
    Cyberpower
    AMD Phenom X4 9850
    MSI K9N SLI V2
    8 GIG DDR 800
    EVGA 9800 GT 512mb
    onboard
    SyncMaster 220wm
    650 watts
I stuumbled across that windows performance monitoring tool, or whatever it is, and it had a small note there that new hardware was detected, but never got the usual message on re-boot. Is this normal for Vista?
by the way , my graphics scores went from a average of 4.1 up to 5.7
    ZT Systems 7308Ma
    ASUS M3A78-EM
    6GB DDR2 Memory
    1280 by 1024
    ATX 12V 300W
that is wierd, because I score a 5.1 on my work laptop with integrated graphics from intel (as we know the worst for integrated graphics)
    Core2Quad Q9550 @ 2.83Ghz O.C'd to 3.86Ghz
    XFX Nvidia 790i Ultra SLI
    4x2GB Corsair DDR3@ 1333Mhz
    Asus Nvidia GTX 280
    Creative PCI Express X-Fi Titanium Fatal1ty Pro Series
    Benq 24in 1920x1080, Viewsonic 22in 1680x1050
    1920x1200 + 1680x1050
    Samsungx2 750GB SATA II 32MB SATA Hard Drive RAID 0 array
    Antec 850Watt
    Cooler Master Cosmo S 1100 Extended ATX No PSU Aluminium Blk
    7x 120mm Fans
    Logitech G7, Logitech G9
    Logitech Dinovo Edge, Logitech Dinovo Mini
    24Mbit p/s
you must have a bad ass laptop
    ZT Systems 7308Ma
    ASUS M3A78-EM
    6GB DDR2 Memory
    1280 by 1024
    ATX 12V 300W
no... as I said, integrated graphics. but it has 3GB of ddr2 ram, core 2 duo, 1.8 Ghz its not bad, but you have a computer with a graphics card, it should kinda kill this...
especially when you can get it for $730AUD or $680USD (just checked then, Australia's Dollar has skyrocketed to about .86 USD)
    Asus Nvidia GTX 280
    Antec 850Watt
    7x 120mm Fans
    24Mbit p/s
my graphics rating was 5.9 and gaming graphics 5.5.
thats with a 8600GT, which isnt anywhere near the latest nor greatest graphics card, but still? maybe laptops use a different grading system, like against other laptops instead of against desktops
    ZT Systems 7308Ma
    ASUS M3A78-EM
    6GB DDR2 Memory
    1280 by 1024
    ATX 12V 300W
That could definitely be it. Or maybe with the rating system They add the average score for each component ie, the graphics gets added as a 1 if its good 1.1 if its really good or 0.5 if its dodgy. cpu same, ram, etc, etc. so the score will only make sense if you analyse the individual scores and not the aggregate value shown
Here's some rep you seem alright
    Asus Nvidia GTX 280
    Antec 850Watt
    7x 120mm Fans
    24Mbit p/s
You have to bare in my that when the WEI in Vista was coded, the 8600 wasn't considered old. Drivers also appear to have a bit of influence over the score.
At any rate, the main thing is that it's installed. Just double check in Device manager that there are no yellow triangles beside any display devices to ensure it was a 'clean hand over'.
    i7 3770K HT ON 4.7GHz
    P8Z68 Deluxe Gen 3
    8GB G.Skill Ripjaws X 2133mhz
    X-FI Forte + ATH-AD900
    1920*1200 / 1920x1080
    Corsair AX1200W
    Lian Li PC-V1020A
