Call of Duty 4 Freezes and pixels go strange
First off you should update the components used for gaming, so download and install the following:
1- Make sure you download and install the latest software from here: NVIDIA Graphics
2- Install these updates:
DirectX (You need this whether you running DirectX 9, 10 or 10.1)
C ++ for Vista 32 bit
Once you've installed the above reboot your pc. Once your back at the desktop download this: Utilities.zip It contains three shortcuts, when you run the defrag shortcuts it open a cmd window. That window will close by itself when it is finished so be patient. Once the last shortcut has completed reboot your pc again and then try playing your game.
bump
    Asus
    AMD Phenom(tm) 8650 Triple-Core Processor (3 CPUs), ~2.3GH
    ASUS M2N68-CM Motherboard
    4094MB RAM
    NVIDIA GeForce 9500 GT
    Speakers VideoLogic ZXR-550/Microsoft LifeChat LX-3000
    ViewSonic VE700
    1280 x 1024
    1TB Samsung
    ASUS TA-K5
    CPU Funnel
    Microsoft USB IntelliMouse Optical
    Microsoft Digital Media Pro Keyboard
    Dial Up
Oops, just saw your post.
I don't see disk defragmenter fixing this. I'll try anyway.
    Asus
    4094MB RAM
    ViewSonic VE700
    1280 x 1024
    1TB Samsung
    ASUS TA-K5
    CPU Funnel
    Dial Up
Unsucessful. The problem is still occuring. Does anyone have any idea why? It does NOT happen on XP.
    Asus
    4094MB RAM
    ViewSonic VE700
    1280 x 1024
    1TB Samsung
    ASUS TA-K5
    CPU Funnel
    Dial Up
Okay guys, I have a possible fix!
I've went into task manager > processes > iw3mp.exe > set affinity
Uncheck all except CPU0, make sure there is a tick there.
I was playing for over an hour without a freeze. It's not guarenteed YET, but it looks promising.
Thanks for the help guys.
For everyone having the same issue,
Good luck, people.
    Asus
    4094MB RAM
    ViewSonic VE700
    1280 x 1024
    1TB Samsung
    ASUS TA-K5
    CPU Funnel
    Dial Up
that's exactly the symptoms i had 3 days before my 8800 gts died, i fear that your graphic card might be failing, especially if you didn't have this problem before, of course it could be other things.
    costume
    intel core 2 Quad q9550 2.8 ghz
    EVGA NFORCE 790i ULTRA SLI
    4 GB ocz
    nvidia 8800 gts 640 MB
    xfi xtreme gamers
    sceptre x24
    1920x1080
    seagate 1000 GB
    pc power & cooling
    HAF
    2.5 mbit
Actually I had that same problem with CoD4 W@W and MW2. It was because I was overclocking. Turn your overclock off and it will work just fine.
    Powered By Asus Built By Me
    AMD Athlon II 250 Regor 3.0GHz
    AsusTek M3A76-CM
    2x 2048MB DDR2 PC6400 OCZ High Performance Gold Edition @ 2.1v
    ECS Geforce GTS 250 512MB
    Via Onboard
    Acer X203H Compaq FS740
    Acer-1600x900 Compaq 1280x1024
    Seagate Barracuda 250GB 7200 RPM Western Digital Caviar 80 GB 7200 RPM
    A-Power 680 Watt PSU
    Power Up Micro ATX Case
    1x 120mm Case Fan 1x 80mm Case Fan
    OCZ Equalizer 7 Button Laser Gaming Mouse
    Microsoft Comfort Curve Ergonomic Keyboard
    6Mbps
    1x 1024 PNY Flash Drive Integrated In Windows ReadyBoost.
