BSODs 2
Memtest is know to be the most accurate, go with that.
Tested with memtest for 8 passes,got 0 errors.
    AMD Athlon(tm) II X4 620 Processor
    4.00GB DDR2
    ATI Radeon HD 5700 Series
    ATI high definition audio device,Realtek High Definition Aud
    Generic PnP Monitor
Take a good ram stick and test each slot for 4 passes. If that is ok, we can rule out Memory. If not memory it looks like a driver or other hardware issue.
Test drivers
Driver Verifier Inst
Since the driver that crashed you has not been listed you should run driver verifier
Please run Verifier with these settings:
Using Driver Verifier is an iffy proposition. Most times it'll crash and it'll tell you what the driver is. But sometimes it'll crash and won't tell you the driver. Other times it'll crash before you can log in to Windows. If you can't get to Safe Mode, then you'll have to resort to offline editing of the registry to disable Driver Verifier.
So, I'd suggest that you first backup your stuff and then make sure you've got access to another computer so you can contact us if problems arise. Then make a System Restore point (so you can restore the system using the Vista/Windows 7 Startup Repair feature).
Then, here's the procedure:
- Go to Start and type in "verifier" (without the quotes) and press Enter
- Select "Create custom settings (for code developers)" and click "Next"
- Select "Select individual settings from a full list" and click "Next"
- Select everything EXCEPT FOR "Low Resource Simulation" and click "Next"
NOTE: You can use Low Resource Simulation if you'd like. From my limited experimentation it makes the BSOD's come faster.
- Select "Select driver names from a list" and click "Next"
Then select all drivers NOT provided by Microsoft and click "Next"
- Select "Finish" on the next page.
Reboot the system and wait for it to crash to the Blue Screen. Continue to use your system normally, and if you know what causes the crash, do that repeatedly. The objective here is to get the system to crash because Driver Verifier is stressing the drivers out. If it doesn't crash for you, then let it run for at least 36 hours of continuous operation (an estimate on my part).
Reboot into Windows (after the crash) and turn off Driver Verifier by going back in and selecting "Delete existing settings" on the first page, then locate and zip up the memory dump file and upload it with your next post.
If you can't get into Windows because it crashes too soon, try it in Safe Mode.
If you can't get into Safe Mode, try using System Restore from your installation DVD to set the system back to the previous restore point that you created.
Just reinstalled whole system:)
Just one last question,which anti virus should I use?(Free one)
atm got norton installed.
    4.00GB DDR2
    Generic PnP Monitor
Security Essentials as said above.
Run a malwarebytes scan once a week.
Use WinPatrol. It is a pseudo Anti Virus. It has many good features those that have it cannot live without it, as do I.
Finally download and use Secuia. It will insure that your AV and other SW is always up to date.
Downloaded all of above,thanks for help...See ya in future if i receive new problems with BSODs.:)
    4.00GB DDR2
    Generic PnP Monitor
It was a pain to reinstall, but it was the right choice.
If you have a problem again, go to the Windows Seven upgrade advisor and run the scan. It will point out hardware errors.
