Bsod urgent help needed!!!!!
yes i am? Ive tried updating the sound card but it keeps telling me its updated properly and has the latest updates? how can i update it more?
    Gigabyte
    AMD Athlon(tm) 64 X2 Dual Core Processor 6400+ 3.20 GHz
    ASUS Gigabyte S
    3.5Gb
    Nvidia GeForce 9600Gt 512mb
    Realtek high Definition
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
So your using a audio port from a sound card, not the motherboard correct? if this is correct, pull the sound card out and see if you still get the BSoD
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
sorry i was mistaken, i dont have a sound card its plugged into the motherboard
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
no more help? if not then thank you and i guess ill have to go see a technician
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
Post the latest minidump file and we will take a look, just to see if it's the same error.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
here it is
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
This one was caused by your Video driver. "nvlddmkm"
Do you have the latest driver, if so, try an older one, or experiment with different drivers.
The fact that this is a different driver causing the BSOD may point to a memory/hardware problem, the only way to find out for sure is to try a different driver/drivers, and see what happens.
Probably not what you wanted to hear, but unfortunately there is no easy answer to this.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
i tried to uninstall the latest driver but it wouldn't come up in my updates list? how can i locate an old driver for my graphics card and install it to see if it solves my bsod?
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
Use option two to check that you have the latest driver.
If you look down the page, there is a link to Beta and Archived Drivers, this is where you will find all the past drivers used.
Drivers - Download NVIDIA Drivers
Always go to the manufacturer's site for all drivers.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
wow 2 hrs of solid gaming and no bsod!!!!! hahaha thankz for the help man!!!! much appreciated!!!!
2 much kuziez!!!!
    Gigabyte
    ASUS Gigabyte S
    3.5Gb
    VeiwSonic 22" LCD
    1024 by 768 pixels
    320Gb
    Logitec
    Logitec
    1.5mbs
Lets hope that is the problem solved. :party:
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Simple as an audio and video driver. Perfect :)
    HP
    Intel Neo
    2GB
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
