Solved BSOD + Stuck on Waking up from Sleep
That is a list of your drivers, that were in use during the BSOD
Just in case anyone see's this in the future and for your information, I don't use iTunes at all as AFAIK I haven't EVER installed it, much less anytime recently since the Waking up from sleep BSOD crashes. I suspect it might be MediaMonkey or SongBird, as those are the only apps I remember installing involving music.
Also, after running the verifier as soon as I rebooted it crashed when loading windows, I didn't get a chance to actually try putting it to sleep and waking it up! This could probably mean that afs.sys is NOT the cause right? :(
I still haven't tested it once I test it I will let you know :)
Success! I've tried putting it on sleep and waking it about 2 times now and it seems to work! :D
Thank you VERY much Rich, I really don't think I would've figured it out without you! Not many people are so patient, you still responded after more than a month of no reply from me!
I don't think that problem should occur again but if it does I will let you know!
Thanks a lot once again and Take care :)
P.S. That Driver verifier is a charm :D
All the members appreciate rep, its a way of saying thanks. All the members, like that nice smiley and the thank you for both, very generous.
Im glad that it worked out and glad that you reported back.
Before I forget. Any new BSODs, just post, we will be here for you.
