BSOD problems, need help.
    HP-Pavilion m9280.uk-a
    ASUS NVIDIA Geforce GTS450
    HP w2408 24.0" (Dual monitor)
    1920 * 1200, 1920 * 1200
    40 Meg
Alright im about to do that, sorry for the late reply i went to a friends for a couple days.
    HP-Pavilion a6645f
    AMD Athlon(tm) Dual Core Processor 4850e 2.50 GHz
    PEGATRON CORPORATION NARRA3
    Nvidia GeForce 9800 GT
    HP w1907 19.0"
    1440 * 900
OK, I uninstalled the Drivers, Ran CCleaner, rebooted into safe mode and attempted to install the drivers, Graphics Driver and 3D Drivers installed correctly but once again PhysX System Software failed to install.
    HP-Pavilion a6645f
    HP w1907 19.0"
    1440 * 900
    40 Meg
It said i already have the newest version of PhysX Software, is it possible that it's just telling me it failed when it didnt? or that i already had it and it wasnt removed when i removed the drivers?
    HP-Pavilion a6645f
    HP w1907 19.0"
    1440 * 900
No,
The second link implies you should install the old version of PhysX prior to updating.
Therefore I am suggesting we follow that instruction as you seem to be unable to install the fully updated version directly. After all I would like you to successfully install the software too.
    40 Meg
are you saying i need to uninstall PhysX 910.05.14 and then install those 2 you gave me? if so, i cant find PhysX 910.05.14.
    HP-Pavilion a6645f
    HP w1907 19.0"
    1440 * 900
Look for the Old version of the PhysX in search and in control panel uninstall programs. If found uninstall using revno. Then download Ccleaner to make sure all remnants are gone. Then install the new one. If still problems do it in safe mode.
I did not go through this entire thread. I do not know if uninstalling is the correct thing to do etc. I am just trying to help with the last few posts.
Revo Uninstaller Pro - Uninstall Software, Remove Programs easily
Piriform - Download CCleaner, Defraggler, Recuva, Speccy - Millions of users worldwide!
Ccleaner is great. Be sure to uncheck all the registry entries, unless you are proficient in that area and ask us about any other ticks you are not familiar with.
You will like it once you are familiar with it and will use it once a week like me
Good luck
ya ive actually used CCleaner for a little while although i didnt have the mode up to date one but now i do and i looked everywhere i could think of but i cant find any trace of physX
    HP-Pavilion a6645f
    HP w1907 19.0"
    1440 * 900
That sounds good because we do not want that version or any trace of it on your system prior to installing the old versions.
Give the install options a go: -
This one first!
http://www.nvidia.com/object/physx_8.09.04_whql.html
Then this one: -
NVIDIA DRIVERS 9.09.1112
Then re-install your original drivers to fully update the PhysX to 9.10.0514
Post back what happens (If possible, capture some failure screens).
    40 Meg
