Microsoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Mini112010-01[1].zip\Mini112010-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x64
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`0205b000 PsLoadedModuleList = 0xfffff800`0221fdd0
Debug session time: Sat Nov 20 02:29:27.713 2010 (GMT-5)
System Uptime: 0 days 2:32:18.061
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 50, {fffff6ffffc433e0, 0, fffff800020d806e, 2}
Could not read faulting driver name
Probably caused by : memory_corruption ( nt!MiUpdateWsle+29e )
Followup: MachineOwner
0: kd> !analyze -v
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: fffff6ffffc433e0, memory referenced.
Arg2: 0000000000000000, value 0 = read operation, 1 = write operation.
Arg3: fffff800020d806e, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 0000000000000002, (reserved)
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002282080
fffff6ffffc433e0
FAULTING_IP:
nt!MiUpdateWsle+29e
fffff800`020d806e 498b00 mov rax,qword ptr [r8]
MM_INTERNAL_CODE: 2
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
BUGCHECK_STR: 0x50
PROCESS_NAME: ~e5.0001
CURRENT_IRQL: 0
TRAP_FRAME: fffffa600fe896f0 -- (.trap 0xfffffa600fe896f0)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=0000007ffffffff8 rbx=0000000000000000 rcx=0000098000000000
rdx=ffffffff8867c001 rsi=0000000000000000 rdi=0000000000000000
rip=fffff800020d806e rsp=fffffa600fe89880 rbp=00000000000000da
r8=fffff6ffffc433e0 r9=0200000000000000 r10=0000000fffffffff
r11=fffffa8000000028 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0 nv up ei ng nz na pe cy
nt!MiUpdateWsle+0x29e:
fffff800`020d806e 498b00 mov rax,qword ptr [r8] ds:fffff6ff`ffc433e0=????????????????
Resetting default scope
LAST_CONTROL_TRANSFER: from fffff80002115ada to fffff800020b54d0
STACK_TEXT:
fffffa60`0fe89608 fffff800`02115ada : 00000000`00000050 fffff6ff`ffc433e0 00000000`00000000 fffffa60`0fe896f0 : nt!KeBugCheckEx
fffffa60`0fe89610 fffff800`020b4059 : 00000000`00000000 fffffa80`0396ab00 fffffa60`0fe89a00 fffff700`01080498 : nt! ?? ::FNODOBFM::`string'+0x2c465
fffffa60`0fe896f0 fffff800`020d806e : fffff700`01080498 00000000`000000da fffffa80`04471330 00000000`00000001 : nt!KiPageFault+0x119
fffffa60`0fe89880 fffff800`020ceff0 : fffff700`01080498 fffff680`003bcc18 00000000`00000000 00000000`00000000 : nt!MiUpdateWsle+0x29e
fffffa60`0fe898e0 fffff800`020cf2d9 : 00000000`000005e5 00000000`a8968121 00000000`779838c9 fffffa80`01f9c380 : nt!MiCompleteProtoPteFault+0x270
fffffa60`0fe89960 fffff800`020cdfd0 : 00000000`00000510 00000000`00000000 00000000`0045f120 fffffa80`04471330 : nt!MiResolveProtoPteFault+0x129
fffffa60`0fe899e0 fffff800`020cb9dd : 00000000`00000000 00000000`779838c9 fffffa80`082853d0 00000000`00000000 : nt!MiDispatchFault+0x190
fffffa60`0fe89b40 fffff800`020b4059 : 00000000`00000008 00000000`02f0f908 00000000`00000001 00000000`0045e2c0 : nt!MmAccessFault+0x32d
fffffa60`0fe89c20 00000000`779838c9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiPageFault+0x119
00000000`0045dfd0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x779838c9
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!MiUpdateWsle+29e
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: nt!MiUpdateWsle+29e
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4c0e5ae3
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: X64_0x50_nt!MiUpdateWsle+29e
