Solved BSOD Help!
Sadly after putting in the other CPU, an e6300, i have had 5 BSOD/crashes in about an hour...Seems like once the system starts to crash, it crashes a lot.
    Q9400
    Gigabyte EP45-UD3L
    Patriot
well, even though my memory passed memtest repeatly a week ago, i just started it again (more or less pulling my hair out at this stage), and what do you know, i get an error this time.
so, i have new memory on the way, should be here early next week, i'll post back then. (yes, that means that the 1st set of ram i was using failed memtest, and now the 2nd set, which i've been using about 10 days, also now fails memtest, hopefully 3rd times a charm!)
thanks again for your patience and help in my thread, i greatly appreciate it!
    Q9400
    Gigabyte EP45-UD3L
    Patriot
Well I'm not glad to hear the RAM is bad, but at least it seems you've found the culprit! Let us know how it goes.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
with the new memory, things are working well!
thanks for all your help guys!
    Q9400
    Gigabyte EP45-UD3L
    Patriot
Although I haven't really helped you here, I just wanted to thank you (on behalf of myself and my colleagues) for taking the time to say thanks :)
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Jonathan King
    1024x768
    Antec ea-430d 430W
    Antec 300
