BSOD, constantly reboots
DG
got it. now about half are zero file size but there are enough to get a good idea
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
Just managed to finish the sfc scan, barely... just crashed -_-
Anyways, it said it found some corrupt files I believe, but was unable to fix them, or something along those lines. I believe it made a log file, if I can get back on long enough I will upload them.
    Velocity Micro / ProMagix E2215
    Intel Core 2 Duo E6600
    Asus P5N-E SLI
    DDR2 4096MB (4 Sticks)
    GIGABYTE GeForce 9800 GTX+
    HDTV 42"
    1366 x 768
    WDC WD10 01FALS-00J7B SCSI 931GB
    550W ?
    Velocity Micro
    Lots of Fans
    15mbps Cable: Comcast
DG
Ok Are you over clocking? How much ram?
the first five dumps are virtually identical. they all are caused by memory corruption. I dont know if you have added memory or changed something. I would first download memtest86 and thoroughly test the ram. If that passes try pulling the ram and re-seating it. It still BSOD take out all b ut 1-2 gigs. If bsod stops with less ram its either the ram or cpu.
ken
Microsoft (R) Windows Debugger Version 6.11.0001.404 X86
Loading Dump File [C:\Users\K\Desktop\Mini092609-04.dmp]
Symbol search path is: SRV*d:\symbols*Symbol information
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 6002.18005.x86fre.lh_sp2rtm.090410-1830
Machine Name:
Kernel base = 0x82407000 PsLoadedModuleList = 0x8251ec70
Debug session time: Sat Sep 26 15:42:12.335 2009 (GMT-4)
System Uptime: 0 days 0:01:25.116
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 4E, {7, 1e8ef, 10, 0}
Probably caused by : memory_corruption ( nt!MiPfnReferenceCountIsZero+2a )
Followup: MachineOwner
1: kd> !analyze -v
PFN_LIST_CORRUPT (4e)
Typically caused by drivers passing bad memory descriptor lists (ie: calling
MmUnlockPages twice with the same list, etc). If a kernel debugger is
available get the stack trace.
Arguments:
Arg1: 00000007, A driver has unlocked a page more times than it locked it
Arg2: 0001e8ef, page frame number
Arg3: 00000010, current share count
Arg4: 00000000, 0
Debugging Details:
BUGCHECK_STR: 0x4E_7
CUSTOMER_CRASH_COUNT: 4
DEFAULT_BUCKET_ID: COMMON_SYSTEM_FAULT
PROCESS_NAME: msnmsgr.exe
CURRENT_IRQL: 2
LAST_CONTROL_TRANSFER: from 824844d1 to 824be2cf
STACK_TEXT:
a5a889e0 824844d1 897a5b70 89926020 000000a2 nt!MiPfnReferenceCountIsZero+0x2a
a5a88a30 82487fdd 8992cf20 00000000 00000000 nt!MiWaitForInPageComplete+0xafd
a5a88a44 826121ad 00000000 9c395be4 9c395bb0 nt!MiPfCompletePrefetchIos+0x1a
a5a88a70 825c0dec 000000a3 acb2fae0 00000001 nt!MmPrefetchPages+0x1c3
a5a88ae8 825c001c 00a88b0c 00000000 00000000 nt!PfSnPrefetchSections+0x34b
a5a88c64 825d35f0 9c394000 a5a88c94 a5a88ca0 nt!PfSnPrefetchScenario+0x121
a5a88cf8 825d3690 82621687 8972a638 a5a88d50 nt!PfSnBeginAppLaunch+0x382
a5a88d08 82621236 a0001870 00000000 00000000 nt!PfProcessCreateNotification+0x65
a5a88d50 82445efe 00000000 776f5e58 00000001 nt!PspUserThreadStartup+0x116
00000000 00000000 00000000 00000000 00000000 nt!KiThreadStartup+0x16
STACK_COMMAND: kb
FOLLOWUP_IP:
824be2cf f6470801 test byte ptr [edi+8],1
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: nt!MiPfnReferenceCountIsZero+2a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP: 49e0199e
IMAGE_NAME: memory_corruption
FAILURE_BUCKET_ID: 0x4E_7_nt!MiPfnReferenceCountIsZero+2a
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
4 Sticks, 1g each. Not overclocking.
I had this tower transported UPS from Texas to Chicago, so the sticks might have gotten jumbled around a little, no telling. Still having major trouble logging in without a BSOD so I will try removing some and see if it makes a difference. Thanks.
    Asus P5N-E SLI
    HDTV 42"
    1366 x 768
    550W ?
    Velocity Micro
    Lots of Fans
I removed the 4th stick and what do ya know, I log into desktop normally and no BSOD. I'm still a bit on edge though, worked fine hours last night and pooped on me again this morning. But I'm hoping that that 4th stick of ram is the problem, not sure if it was just loose or corrupt but removing it seems to have things working smoothly... for now. If it is the problem, what do you suggest I do from here, since I'm out 1g of ram. I'm tight on cash so I'd rather not replace it. When the tower arrived UPS, I had opened to case and made sure everything was in properly. If it's corrupt is there any way of fixing it without having to get passed 50 BSOD in the process? One thing I noticed about my last 2 sticks of RAM, they seem a little wider, because they don't seem to go down far enough to get a good 'clamp' on each side, like the first 2 sticks. Although they worked fine forever till I moved, I'm hoping it was loose and will work fine once I put it back in.
    Asus P5N-E SLI
    HDTV 42"
    1366 x 768
    550W ?
    Velocity Micro
    Lots of Fans
DG
with the computer off you should pull all four and re seat them. check to make sure they are the same speed, latency, etc
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
Well, I'm doing fine with one less stick of RAM, maybe later on I'll buy another to replace the 4th. But yeah, problem solved, thanks for all the help. -DG
    Asus P5N-E SLI
    HDTV 42"
    1366 x 768
    550W ?
    Velocity Micro
    Lots of Fans
DG
glad y ou are working even if it is with one less stick. YOu might want to try that stick in another slot to see if it is the stick or the slot
Ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
