BSOD constantly, not sure what to do. please help. Virus is crashing it.
When you are sure that it is working fine, turn on one more service. If it works fine turn on another. We will find out what is causing the problem.
Be sure that the computer is working fine before turning on the next service.
So i've now gotten to the point where every single service is disabled, but i still am getting bsod's. What do i do know? all services and startup things are off, but yet i still get bsods. what now?
    Q6600 Intel quad core
    GA-EP45-DS3L
    4gb of crucial memory
    AMD 6700 HD
OK, this makes things a bit more difficult, but we will get done.
Turn on all services and then boot in safe mode, does it work now?
Is this problem resolved?
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
No, this is not resolved. I've run it in safe mode for a long time, and no crash. But that does not mean the problem is resolved because it can run in normal mode without crashing sometimes for a day or two. When i put it back in to normal mode, it crashed within a few hours. I am going to attach a picture of what the computer did when it crashed. View attachment 27813 Sorry about the annoying bad camera quality on the right side. When the computer crashes it either does this, or it does a BSOD.
    GA-EP45-DS3L
    AMD 6700 HD
Since your display is screwed up, it appears to be the graphics card may be overheating. I don't know if you have a PC or a laptop. If you have a PC, is the GPU fan running and is it clean? Is its speed changing with various loads? When you get the BSOD, the offending item is usually listed near the bottom of the screen. Can you see it and provide it here? If you have a laptop, make sure the vents are clean.
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
That's what I thought at first, so I replaced the graphics card with an older card that I have that I know works, and still the same problem, constant bsods. The temp of the card is fine and the fans are all working correctly according to CPUID. Also, it is a desktop. When it crashes with all the services turned on, it says on the bsod, USB near the bottom but when it crashes without the services turned on, it doesn't seem to point to anything. Also, I've noticed that if I have chrome running for awhile with more then one tab and then decide to close chrome, a bsod is almost guaranteed. Weird.
    GA-EP45-DS3L
    AMD 6700 HD
Normally, near the bottom of the BSOD it will indicate a .dll or other file that is causing the problem. Just the word USB doesn't sound right. Can you give us the exact wording?
    Cyberpower
    NVIDIA 780i
    Viewsonic VG2436
    1920x1080p
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
It generally goes by pretty quickly and ya it doesn't just say USB, that's just the beginning of it. I'll try to write it all down next time it comes up.
    GA-EP45-DS3L
    AMD 6700 HD
