Solved Broadcom 802.11N network adapter Driver problem
I've been having the same issue for 4 years now. Mine arose from using spring wireless internet. You said that you cannot go online... Broadcom 802.11N network adapter wont cause you from connecting (I'm replying from the pc that has the same issue as yours.) So I would suggest to see what's gone wrong. Having all the CDs that came with the PC are a major help. However, the problem with the adapter is not getting solve that way - I tried.- I'm trying to find a way or software that can tell me what in specific is conflicting w. the adapter but NOTHING HAS WORK SO FAR. I no longer own sprint products of any kind and have uninstalled all useless drivers.
I hope someone can tell us a solutions... this issue is making updates hard to install
Hello, this Thread is solved, he downloaded the drivers and installed them. Have you tried getting your drivers ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
The OP of this thread went to computer manufacture and got his drivers. Dell is where he went .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
