Boot Up Problem!
ok well thats one thing less to worry about you may have to do a clean install anyway, what mother board are you using does it have dual bios? access the bios and select to return to factory settings or similar option to reset the bios and try again if that works you won't have to do a clean install but if it doesn't you'll need a clean install and when you do that all files are put into a folder called windows old so you won't lose anything apart from apps
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    8 GB OCZ 1066 HPC REAPER
    Sapphire 4870 HD 1024mb gddr5
    lg flatron 20.1
    western digital 350gb samsung spinpoint 120gb
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
Sorry for being so difficult but nothing I found could disable the auto reboot. But is there any type of installation that will reset or change my HAL and keep all of my programs
Sorry for being so difficult but nothing I found could disable the auto reboot. But is there any type of installation that will reset or change my HAL and keep all of my programs an files.
if you could get a copy of your bios you could flash it but i would not recomend that for a home user.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
I just tried resetting my BIOS and still didn't boot. I am also hesitant because I don't remember all of my apps :/ and I have System Mechanic and I've run out of keys for that. But atleast all of my files would still be there
Hello I've recently had an AMD Athlon 64 X2 5400+ installed on my Dell. Now my computer gets to the progress scroll bar page then it goes black and reboots. I've tried repairing and restoring but both are unsuccessful. I want to avoid a clean install as much as possible. Can someone please help me get my computer working. Any help is appreciated.
Who installed the cpu for you?
While a dual core uses a different version of HAL than a single core, if the motherboard is the same and its bios supports the new dual core cpu, you should have no issues whatsoever. Windows, as long as the previous requirements are met, will recognize the new cpu and use the proper HAL. I've done this more than once, so I know you don't need to reinstall as long as the motherboard is unchanged.
You should find out if your current bios supports dual core cpus? Could you provide us with more info (as much as you've got) on this Dell? We need to see anything and everything you've got on the board.
I suspect it's your bios. If that's the case, you're going to have to bring the machine back to whomever installed the cpu for you, have him put back your old cpu and flash to a later bios.
I would be pissed though... that machine should have never left in the state that it's in.
    Fumz' Flux-Capacitor
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    500GB W.D. RE2 Primary 1TB W.D. Caviar GP WD10EACS
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
your files will be safe. last time i did a clean install it copied the entire windows folder all apps and everything from my c drive including programme files but i could not move those apps across as they need to create registry info and so forth which is done during installation but think of this as a fresh start, and it will give you the chance to not install those apps you thought were usfull but never used.
    me
    intel Q6600 @3.0Ghz
    gigabyte EP35C DS3R
    lg flatron 20.1
    900w
    thermaltake aguila
    2x 120mm 2x 10cm
I have a Dell Dimension C521.
My old processor was an AMD Sempron 3400+(single core)
My chipset is an Nforce 430
My ram is 512(used to be 1.5gb but then my 1 gig stick was defective)
My Graphic Card is a GeForce 6150LE
I don't know myh motherboard.
So every file and program is still there but in a folder called Old Windows? So I would still have them so I could decide which to reinstall?
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
Yes I noticed you have H. Basic, it could be. I wouldn't do anything until you got more RAM.
You need to have a talk with whoever installed the CPU.
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
Later :shock: Ted
Ok I'll wait for the more RAM and contact my installer for help, otherwise in a few weeks I will bring back this topic. Thanks to everyone who posted.
I hope you get it sorted, yes please post back and let us know ... ;)
Later :shock: Ted
    * BFK Customs *
    ASUS P5Q Pro
    Realtek HD 7-1
    Corsair 620HX
    CM Cosmos RC-1000
    18.6Mb/s
    My First Build ;)
If you're planning on taking the machine back to the same guy who let it out of his door in the condition it is... I would consider someone else. :confused:
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
The people who installed your CPU should have known and informed you that 512MB of RAM would be a problem, and reputable techs would not have done a CPU swap until your machine was stable as far as hardware is concerned, a question.. maybe i missed it... was the machine running with this new CPU? If so...was it running with only the 512MB of RAM? Or...did the problems start after your RAM went bad? For the forum Techs....could that machine need RAM in pairs?
    Q9550 2.83 Quad
    8 GB OCZ 800MHz
    Nvidia 9800 GT 1GB
    LG 24
    2 500 GB 32MB Seagate( Raid 0 ) 1 1000 GB 32MB Seagate
    PC P{ower and Cooler 1000W
    HP d5000t ATX CTO
No the motherboard was not changed. I went from an AMD Sempron 3400+ to AMD Athlon 64 x2 5400+. I don't have my old cpu. Doesn't the back up back up my programs too?
Ok, let's try and see what the error is. Turn on the computer, and after the POST, but before windows begins to boot, continually press F8 to get to the boot menu. If there is an option to "Disable automatic restart on system failure" (like on XP), then select it. If the system resets now, the error message should stay on screen. Make a note of what it says (as much detail as possible).
From there, we may be able to give further instruction.
Also, try resetting the BIOS to failsafe defaults.
Ok, and I tryed pressing F8 but nothing came up
If continually pressing F8 before Vista starts doesn't help, then do you get a boot menu that state Vista didn't start properly? This menu usually gives 30 seconds before normal booting resumes. If you press F8 then, what happens?
    AMD Phenom 9600 Quad
    ASUS MB-M3A32-MVP Deluxe/WiFi
    2 x A-Data 2GB DDR2-800
    ASUS ATI Radeon HD 2400PRO
    SAHARA 21"
    1600x1200
    800W
    Thermaltake Tai-Chi
    Tai-Chi Water Cooler
    Genius
    384kbps
Hi upinflames,
I have just had a look at the documentation for your motherboard (links below). In the 'Owners Manual' (2nd link), refer to the section headed 'Advanced Troubleshooting' beginning on page 47. What is the pattern of the 'Diagnostic Lights' as shown in this section? These lights are on the front of your system, numbered 8 in the image below.
Documentation
http://support.dell.com/support/edocs/systems/dimc521/en/OM_EN/RP333A00.pdf
Documentation
http://support.dell.com/support/edocs/systems/dimc521/multlang/PM/DAO/PY374A01.pdf
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
When they installed the cpu they noticed that the RAM was defective and cuasing my computer problems so they removed it.
Nothing.
The more you describe them, the less legit they seem. Just so we're straight: you brought them your working machine so they could replace the cpu. They handed you back an inoperable machine, and told you they had to remove 1GB of your RAM, "because it was bad", and, if that weren't bad enough on it's own, kept your old cpu and this "bad RAM"?
My god... I don't know where to begin? I mean your machine worked before you brought it in, so you know they're full of sh!t and that they just ripped you off 1GB of RAM. They also ripped you off a working, fully functioning, fully sell-able cpu. What right do they think they have to keep your parts? And, lets not forget that (giving them the undeserved benefit of the doubt) they claimed to test, but let you walk out of the door with a machine that will not boot... this isn't pc repair, it's criminality.
    E8400
    DFI LP DK P35-T2RS
    4GB G.Skill PC-1066
    eVGA 8800 GTS
    X-Fi XtremeGamer
    Samsung 226BW
    Lian Li Lancool K62
    Logitech G5
    2.5MB/430
    D-Link DGL 4500
