Boot Scan Fail
I'm not sure if I can do that... I'm using a laptop and the box it came in, along with all the provided CDs had been thrown out without my permission a long time ago.
Yah :> same avatar I use everywhere.
I'm not entirely sure if this will help as I don't have any problems opening the programs or finding the application to open it with. I'll record a brief video and upload it to youtube and we'll see if it explains any better.
Im bothered by the fact that System Restore did not work. I have not found one situation where it did not work, when the problem could be resolved with changes to the OS.
I read the whole thread over again. In the first post, where you show the screen shot, do you check the box always open with this program?
Did you try to uninstall one program with REVO and then reinstall again? To see if it works
The selection box is grayd out and can't be clicked. As a new discovery, everything will open properly if I right click and press "Run as Administrator" regardless of my never having to do this before. Video is uploading now.
Ok you may have hit on something. I will find the tutorial that corrects that problem. Ill be back.
Hope this explains a little better.
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/mdctI2gJHjQ&hl=en_GB&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/mdctI2gJHjQ&hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]​
You just told me that if you run as administrator it works. The above link will tell you how to set that permanently.
Aha! It is infact working! Major bummer that I'll need to set it for every program I have but none the less, an uncountable time saver in the long run. Thanks a million for your patience, you've been a terrific help.
Your thanks is very appreciated. I do this to help people like you. Everytime a poster comes back and says that it worked I feel great. So thank you
Just change the programs as you use them, dont try to do all at once.
TY for the rep :D
Indeed, just done the programs I'd use daily for now. Will do the rest when I need them. And no worries, mate, you earned it for not giving up after three full thread pages and probably trying just as hard as I was to find a way to fix it. Good luck man, thanks again.
You have a lot of computer expertise, I can tell from your questions and the way you did the you tube video. You will always be welcome here to use our knowledge or to share your expertise with others. Take care my friend.
