Boot Advanced Options - Number of Processors
How to Change the Number of Processors Used at Boot Up in Vista
If you have a multiple core CPU (Ex: Intel Core Duo or Quad CPU) or multiple CPUs, then this will show you how to change the Number of Processors that will be used during boot up for troubleshooting and debugging purposes to be able to determine if there is a problem with a single processor/core, or for a programmer to test their code against a single core while running on their multi-core system.
Vista will use all your processors by default at boot up without this Number of Processors setting box checked. Using all of your available processors (cores or CPUs) durring boot allows the computer to boot faster only because a multiple core CPU or multiple CPUs can handle and do more at once than a single core or CPU. Multiple cores do not actually increase the speed, but only increase the number of processor cores working on the job which in turn has the job finish quicker. If you do not have much running at startup, then you may not notice much improvement in how long it takes to startup.
People have reported that by checking this setting and selecting all of their available CPUs, they have seen a performance increase in boot up speed despite the Note above . See the example below. If it does not help, then you can do step 7 to undo this and go back to the default settings.
Selecting a lower amount of processors to use at boot up than you actually have can increase the amount boot up time causing a longer boot.
EXAMPLE: Boot Up Time Before and After
NOTE:
This is the before and after boot up time for my computer after I changed it to use all 4 cores. For fun you can post your results here: ReBoot Time
NOTE:
Before you do this, you should see what your current boot up time is so you can compare it to what it will be before and after applying this.
1. Open the Start Menu.​
2. In the white line (Start Search) area, type msconfig and press Enter.​
3. Click Continue in the UAC prompt.​
4. Click on the Boot tab. (See screenshot below)​
5. Click on the Advanced options button.​
6. To Change the Number of Processors at Boot -
A) Check the Number of processors box, then click on the drop down arrow and select the number of available processors (cores or CPUs) you want to have used at boot up. (See screenshots below step 7)​
NOTE: To test to see if this can speed up your boot time or not, then select the highest number listed for all of the available processors to be used at boot up and check the Detect Hal box.​
B) Click on OK.​
C) Go to step 8.​
7. To Restore the Default Number of Processors at Boot -
A) Uncheck the Number of processors box.​
B) Click on OK.​
8. Check the Make all boot settings permanent box and click on OK. (See screenshot below)​
NOTE: If you do not check this, then you will Selective startup dotted instead of Normal startup under the General tab. You can still make changes again by checking this again after any changes.​
9. Click on Yes at the confirmation window. (See screenshot below)​
NOTE: You can restore or make changes to this again later if you want. I will confirm it. Just remember or write down what you had set (checked or unchecked) before if you wanted to restore back to those settings later.
10. Check the Don't show this message again box. (See screenshot below step 11)​
NOTE: You will not see this again after checked.
11. Click on the Restart button.​
NOTE: If you checked the box and want to restore this Restart box, see: How to Restore the System Configuration Restart Prompt in Vista
WARNING: This will restart the computer immediately. Make sure you save and close anything open you do not want to lose.
12. After you have started back to the desktop, you can check to see what your new boot up time is for fun.​
LOL, your welcome Rav, and welcome to Vista Forums.
Not sure if this is the right place to ask, but Shawn you seem like a very knowledgeable person so here goes. Came across this forum and your info about using the "Boot Advance Options" to decrease boot time couple months ago and it seemed to work (thank you:cool:) although I did not preform the reboot time check. My questions is what would cause the number of selectable processors to decrease from 2 to 1 in the "Boot Advance Options", I had 2 processors selected, but when I recently check on my system configuration, it had changed to 1 processor and it no longer gives me the option to select 2 processors.
Ran anti-virus software just as a precaution, it did not detect anything.
Also am using Diskeeper 2008, Registry Mechanic, and Auslogics Registry Defrag. Was wondering if any of these programs would cause this change?
Have: Windows Vista Home Premium 32bit, AMD Turion 64 X2 Dual-Core Processor TL-58 2048MB DDR2 SDRAM, 200GB HDD
Any info will be appreciated
Hi Dabusta,
I suppose it can happen from a number of things. A registry cleaning program deleted the wrong entries in the registry, a recent Windows Update, BIOS update, etc...
I would try doing a System Restore using a restore point dated before the option was gone. This tutorial will show you how to if needed.
If that does not help, then you might also run a sfc /scannow command to see if it can find and fix any bad systems files that may be causing this. This tutorial will show you how to if needed.
http://www.vistax64.com/tutorials/66978-system-files-sfc-command.html
Your welcome Dabusta.
i have an amd machine i've tried to run that vb script on this system but got this error Windos Script Host Abc: c:\users\vishal\desktop\boot.vbs LineAb: 2 Char: 9 Error: syntax error Code : 800A03EA Source: Microsoft VBScript Compilation error
OMG
This trick shorten my boot time considerably!
112 seconds to 98 seconds! Wow.
    Core 2 Duo E6600 2.4 Ghz
    Gigabyte P35-DS3R
    Kingston 4x512MB 667MHz DDR2
    nVidia GeForce 8500GT 512MB
    1x Maxtor 200GB 1x External LaCie 250GB (USB 2.0) 1x Western Digital 500GB All are 7200RPM
LOL Lebon, :p
It would depend on if you used the extra horsepower or not at startup. The extra CPUs can do more at once than a single CPU, so it gets done quicker. If you do not have much running at startup (Ex: Programs or drivers), then it may not make to much difference. ;)
I know, I'm not a total noob in computers since I study in Computer Science XD
I have Core 2 Duo 2.4 Ghz. I have desactivated a lot of the start-up processes and it works rather well.
    Gigabyte P35-DS3R
LOL. Just having some fun back with you. :)
I'm happy to hear your computer is running smooth.
Your welcome Zeratulito, and welcome to Vista Forums.
my timing is the same as before >.<
    AMD 5200+x2 Brissy
    Asus M2R32-MVP
    G.Skill 2x1gb DDR2
    ATI 2600XT
    Acer 22"
    160gb
    Rosewill 500W
    NZXT Apollo
    Microsoft
    10MB/1MB
Hi FiReStOrM, and welcome to Vista Forums.
It can happen when you do not have much running at startup.
Selecting to use more than one core or processor durring boot allows the computer to boot faster only because a multiple core CPU or multiple CPUs can handle and do more at once than a single core or CPU. Multiple cores do not actually increase the speed, but only increase the number of processor cores working on the job which in turn has the job finish quicker. If you do not have much running at startup, then you may not notice much improvement in how long it takes to startup.
Thank You Brink =]
oh i see lol...i only have 4 program running at startup =P
    AMD 5200+x2 Brissy
    Asus M2R32-MVP
    G.Skill 2x1gb DDR2
    ATI 2600XT
    Acer 22"
    160gb
    Rosewill 500W
    NZXT Apollo
    Microsoft
    10MB/1MB
LOL, your welcome FiReStOrM.
Just done mine 72 secs (Quad core), also ticked the Memory box to show max memory.
    INTEL QUAD 6600
    Gigabyte EP35-DS4
    4 gb
    GeForce 8800gt
    24" ACER
    1440 X 900
    500 GB 320GB
    700WATT
    ARCTIC
    Av.MTH, Download 8.27, Upoad 0.91
Hi Wysiwyg,
You might want to uncheck the Memory box. By default Vista will use all of your available RAM automatically when this is unchecked. This option is used mostly if you wanted to restrict how much RAM is to be used at boot instead. ;)
That's a pretty good restart time.
