Blurry IE9 text
I allready tryed with the update they said should fix it..but it dident work for me and other people.
Yes i use compatibel mode for all websites, but i haft to resize the Ie 9 browser before the the text gets normal.
thats is the wierd problem..firefox and crome dosent make blurry text
Under the View tab is Zoom at 100% and Text Size at Medium? Also is Style at Default?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Yes the browser is at 100 % zoom an dthe text says times new roman, but it dosent matter what kind of text i use then it doe sthe same thing with the resize browser method
As this seems to be only certain websites it could be to do with the coding and what add-ons they utilize. Are your Java and Adobe Shockwave and Flash players up to date?
Have you ever installed any additional browser helpers at any time that may interfere with things - should be listed in Tools/manage Add-ons?
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
All my drivers and stuff is up to date becaus ei just installed win 7 with the latest updates.
I dont use any other addons, but look at these 3 screen shots
try and read the fuzzy text and then look on the normal text screen shot.
1: The Ie text is fuzzy. It can be readable, but it is not relaxing to read for my eyes.
2: This is from firefox were the text is sharp and relaxing to read.
3: Here the text is normal again in IE 9 after i did the resize browser trick.
So Ie9 CAN show normal sharp text but something is messing it up.
That's strange as number 1 looks the best to me, but as it is a total screen shot and has been reduced in overall size anyway it isn't really big enough for me to judge properly.
Don't you have Snipping Tool in your version of Win 7? That way you can take a section of the desktop rather than the whole thing.
Windows 7 can't be up to date if it doesn't say Windows 7 Service Pack 1 in the right-click of Computer > Properties.
I'm wondering if your monitor is to blame. But as you said it seems exclusive to IE9 so I'm mystified.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Here is 3 more screenshots and i 100 % sure my monitor dosent fail..i have 3 monitors of the same brand and its all the same. and yes it only happend in IE 9 and the text was fine when i had xp and vista before.
But it is like Ie 9 starts with some kind of clear type enable and when i resize the browser in compatibel mode, then it seems like the clear type gets disabled.
And i do have Sp 1 installed
SP1 - good, thanks. The 1st one of those looks the clearest to me. As I said I am very puzzled by this - perhaps post in Microsoft's IE9 Forums as well might not be a bad idea.
Internet Explorer - Microsoft Answers
Sorry I can't help more as I'm out of ideas.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
Perhaps it looks clear for you but my eyes dosent like that kind of text.
But you see the that the text seems like "fat" compared to the others normal
Agreed.
    Win 10 Pro x64 x 2
    Alienware ALX x58
    Unique
    1gb/s up and down
