Yes, exactly. I ran 6 passes on the first card and 12 on the second. No errors were found.
icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp16_Minidump[1].zip\Mini041610-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (4 procs) Free x86 compatible
Built by: 6002.18209.x86fre.vistasp2_gdr.100218-0019
Machine Name:
Kernel base = 0x81c1b000 PsLoadedModuleList = 0x81d28930
Debug session time: Fri Apr 16 19:11:08.293 2010 (GMT-4)
System Uptime: 0 days 5:22:20.259
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
* Bugcheck Analysis *
BugCheck 24, {1904aa, abf90a30, abf9072c, 8a09cad3}
Probably caused by : Ntfs.sys ( Ntfs!NtfsCommonCleanup+2db )
Followup: MachineOwner
3: kd> !analyze -v
NTFS_FILE_SYSTEM (24)
If you see NtfsExceptionFilter on the stack then the 2nd and 3rd
parameters are the exception record and context record. Do a .cxr
on the 3rd parameter and then kb to obtain a more informative stack
trace.
Arguments:
Arg1: 001904aa
Arg2: abf90a30
Arg3: abf9072c
Arg4: 8a09cad3
Debugging Details:
EXCEPTION_RECORD: abf90a30 -- (.exr 0xffffffffabf90a30)
ExceptionAddress: 8a09cad3 (Ntfs!NtfsCommonCleanup+0x000002db)
ExceptionCode: c0000005 (Access violation)
ExceptionFlags: 00000000
NumberParameters: 2
Parameter[0]: 00000000
Parameter[1]: 3f3f3f43
Attempt to read from address 3f3f3f43
CONTEXT: abf9072c -- (.cxr 0xffffffffabf9072c)
eax=3f3f3f3f ebx=00000000 ecx=9e8f02ac edx=9e8f02ac esi=8cc8f920 edi=00020000
eip=8a09cad3 esp=abf90af8 ebp=abf90cf0 iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
Ntfs!NtfsCommonCleanup+0x2db:
8a09cad3 f6400402 test byte ptr [eax+4],2 ds:0023:3f3f3f43=??
Resetting default scope
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
ERROR_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_CODE: (NTSTATUS) 0xc0000005 - The instruction at 0x%08lx referenced memory at 0x%08lx. The memory could not be %s.
EXCEPTION_PARAMETER1: 00000000
EXCEPTION_PARAMETER2: 3f3f3f43
READ_ADDRESS: GetPointerFromAddress: unable to read from 81d476d8
Unable to read MiSystemVaType memory at 81d282e0
3f3f3f43
FOLLOWUP_IP:
FAULTING_IP:
BUGCHECK_STR: 0x24
LAST_CONTROL_TRANSFER: from 8a01d95a to 8a09cad3
STACK_TEXT:
abf90cf0 8a01d95a 9e8f027c 84c17558 21fd478d Ntfs!NtfsCommonCleanup+0x2db
abf90d2c 81c89278 9e8f022c 00000000 ffffffff Ntfs!NtfsCommonCleanupCallout+0x1d
abf90d2c 81c89371 9e8f022c 00000000 ffffffff nt!KiSwapKernelStackAndExit+0x118
9e8f01bc 00000000 00000000 00000000 00000000 nt!KiSwitchKernelStackAndCallout+0x31
SYMBOL_STACK_INDEX: 0
SYMBOL_NAME: Ntfs!NtfsCommonCleanup+2db
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: Ntfs
IMAGE_NAME: Ntfs.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 49e0192a
STACK_COMMAND: .cxr 0xffffffffabf9072c ; kb
FAILURE_BUCKET_ID: 0x24_Ntfs!NtfsCommonCleanup+2db
3: kd> lmtsmn
start end module name
8263c000 82682000 acpi acpi.sys Sat Apr 11 00:19:03 2009 (49E01A37)
8fca4000 8fcec000 afd afd.sys Sat Apr 11 00:47:01 2009 (49E020C5)
89ef2000 89fed000 AGRSM AGRSM.sys Mon Apr 10 06:21:02 2006 (443A318E)
82747000 8274f000 atapi atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8274f000 8276d000 ataport ataport.SYS Sat Apr 11 00:39:10 2009 (49E01EEE)
8f7e4000 8f7eb000 Beep Beep.SYS Sat Jan 19 00:49:10 2008 (47918F56)
8248a000 82492000 BOOTVID BOOTVID.dll Sat Jan 19 02:27:15 2008 (4791A653)
9bc97000 9bcb0000 bowser bowser.sys Sat Jan 19 00:28:26 2008 (47918A7A)
96a90000 96a9e000 cdd cdd.dll unavailable (00000000)
a295a000 a2970000 cdfs cdfs.sys Sat Jan 19 00:28:02 2008 (47918A62)
8a374000 8a38c000 cdrom cdrom.sys Sat Apr 11 00:39:17 2009 (49E01EF5)
824d3000 825b3000 CI CI.dll Sat Apr 11 02:25:22 2009 (49E037D2)
8a1a6000 8a1c7000 CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
82492000 824d3000 CLFS CLFS.SYS Sat Apr 11 00:13:51 2009 (49E018FF)
9bc72000 9bc79780 CO_Mon CO_Mon.sys Wed Aug 08 17:39:53 2007 (46BA3829)
8fefa000 8ff07000 crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a1c7000 8a1d0000 crcdisk crcdisk.sys Sat Jan 19 00:50:29 2008 (47918FA5)
8fee3000 8fefa000 dfsc dfsc.sys Sat Apr 11 00:14:12 2009 (49E01914)
8a195000 8a1a6000 disk disk.sys Sat Apr 11 00:39:14 2009 (49E01EF2)
8f7af000 8f7d4000 drmk drmk.sys Sat Jan 19 01:53:02 2008 (47919E4E)
8ff12000 8ff1a000 dump_atapi dump_atapi.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8ff07000 8ff12000 dump_dumpata dump_dumpata.sys Sat Apr 11 00:39:09 2009 (49E01EED)
8ff1a000 8ff24000 Dxapi Dxapi.sys Sat Jan 19 00:36:12 2008 (47918C4C)
8f526000 8f5c7000 dxgkrnl dxgkrnl.sys Thu Sep 24 21:27:14 2009 (4ABC1C72)
8a16e000 8a195000 ecache ecache.sys Sat Apr 11 00:40:12 2009 (49E01F2C)
8fe68000 8fec6000 eeCtrl eeCtrl.sys Mon Aug 17 19:05:39 2009 (4A89E243)
8fec6000 8fee3000 EraserUtilRebootDrv EraserUtilRebootDrv.sys Mon Aug 17 19:05:39 2009 (4A89E243)
8279f000 827af000 fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
8276d000 8279f000 fltmgr fltmgr.sys Sat Apr 11 00:13:59 2009 (49E01907)
8f7d4000 8f7dd000 Fs_Rec Fs_Rec.SYS Sat Jan 19 00:27:57 2008 (47918A5D)
89ed7000 89ef2000 fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
89c75000 89c7b100 gbpkm gbpkm.sys Tue Sep 15 09:57:08 2009 (4AAF9D34)
8a38c000 8a391280 GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:16:53 2009 (4A1151B5)
81fc6000 81ff9000 hal halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8a2ae000 8a33b000 HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8f743000 8f782000 HdAudio HdAudio.sys Sat Apr 11 00:43:01 2009 (49E01FD5)
9bc05000 9bc72000 HTTP HTTP.sys Sat Feb 20 15:53:31 2010 (4B804BCB)
8a22e000 8a241000 i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
a2970000 a29ba000 IDSvix86 IDSvix86.sys Thu Oct 15 22:09:59 2009 (4AD7D5F7)
8a1fb000 8a20a000 intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
8a241000 8a24c000 kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
82402000 82409000 kdcom kdcom.dll Sat Apr 11 02:25:29 2009 (49E037D9)
8a33b000 8a365000 ks ks.sys Sat Apr 11 00:38:47 2009 (49E01ED7)
89c04000 89c75000 ksecdd ksecdd.sys Mon Jun 15 08:48:53 2009 (4A364335)
8a1d0000 8a1e0000 lltdio lltdio.sys Sat Jan 19 00:55:03 2008 (479190B7)
8ff33000 8ff4e000 luafv luafv.sys Sat Jan 19 00:30:35 2008 (47918AFB)
82409000 82479000 mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
8a367000 8a374000 modem modem.sys Sat Jan 19 00:57:16 2008 (4791913C)
8ff24000 8ff33000 monitor monitor.sys Sat Jan 19 00:52:19 2008 (47919013)
8a24c000 8a257000 mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
82737000 82747000 mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
9bcb0000 9bcc5000 mpsdrv mpsdrv.sys Sat Jan 19 00:54:45 2008 (479190A5)
9bcc5000 9bce6000 mrxdav mrxdav.sys Sat Apr 11 00:14:39 2009 (49E0192F)
9bce6000 9bd05000 mrxsmb mrxsmb.sys Tue Feb 23 06:10:12 2010 (4B83B794)
9bd05000 9bd3e000 mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
9bd3e000 9bd56000 mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
89fed000 89ff8000 Msfs Msfs.SYS Sat Jan 19 00:28:08 2008 (47918A68)
8268b000 82693000 msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8f5dc000 8f60b000 msiscsi msiscsi.sys Sat Apr 11 00:40:07 2009 (49E01F27)
89d87000 89db2000 msrpc msrpc.sys Sat Apr 11 00:37:32 2009 (49E01E8C)
8f6e6000 8f6f0000 mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a15f000 8a16e000 mup mup.sys Sat Apr 11 00:14:12 2009 (49E01914)
a2946000 a2959180 NAVENG NAVENG.SYS Wed Dec 02 13:12:52 2009 (4B16AE24)
a2804000 a2945c80 NAVEX15 NAVEX15.SYS Wed Dec 02 13:19:34 2009 (4B16AFB6)
89c7c000 89d87000 ndis ndis.sys Sat Apr 11 00:45:52 2009 (49E02080)
8f66e000 8f679000 ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
8f679000 8f69c000 ndiswan ndiswan.sys Sat Apr 11 00:46:31 2009 (49E020A7)
8f732000 8f743000 NDProxy NDProxy.SYS Sat Jan 19 00:56:28 2008 (4791910C)
8fd3d000 8fd4b000 netbios netbios.sys Sat Jan 19 00:55:45 2008 (479190E1)
8fcec000 8fd1e000 netbt netbt.sys Sat Apr 11 00:45:35 2009 (49E0206F)
89db2000 89ded000 NETIO NETIO.SYS Sat Apr 11 00:46:21 2009 (49E0209D)
827af000 827bd000 Npfs Npfs.SYS Sat Apr 11 00:14:01 2009 (49E01909)
8fe14000 8fe1e000 nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
81c1b000 81fc6000 nt ntkrnlmp.exe Thu Feb 18 06:01:09 2010 (4B7D1DF5)
8a006000 8a116000 Ntfs Ntfs.sys Sat Apr 11 00:14:34 2009 (49E0192A)
8f7dd000 8f7e4000 Null Null.SYS Sat Jan 19 00:49:12 2008 (47918F58)
8f524000 8f525080 nvBridge nvBridge.kmd Tue Jul 14 15:39:01 2009 (4A5CDED5)
8ec06000 8f5234e0 nvlddmkm nvlddmkm.sys Tue Jul 14 15:54:48 2009 (4A5CE288)
8a392000 8a3d5400 nvmfdx32 nvmfdx32.sys Thu Jul 30 19:47:12 2009 (4A723100)
8fd1e000 8fd34000 pacer pacer.sys Sat Apr 11 00:45:51 2009 (49E0207F)
826ba000 826c9000 partmgr partmgr.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
82693000 826ba000 pci pci.sys Sat Apr 11 00:19:16 2009 (49E01A44)
82722000 82729000 pciide pciide.sys Sat Apr 11 00:39:10 2009 (49E01EEE)
82729000 82737000 PCIIDEX PCIIDEX.SYS Sat Apr 11 00:39:09 2009 (49E01EED)
9bdcb000 9bea9000 peauth peauth.sys Mon Oct 23 04:55:32 2006 (453C8384)
8f782000 8f7af000 portcls portcls.sys Sat Apr 11 00:42:48 2009 (49E01FC8)
82479000 8248a000 PSHED PSHED.dll Sat Apr 11 02:25:32 2009 (49E037DC)
827bd000 827c6000 rasacd rasacd.sys Sat Jan 19 00:56:31 2008 (4791910F)
8f657000 8f66e000 rasl2tp rasl2tp.sys Sat Jan 19 00:56:33 2008 (47919111)
8f69c000 8f6ab000 raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8f6ab000 8f6bf000 raspptp raspptp.sys Sat Jan 19 00:56:34 2008 (47919112)
8f6bf000 8f6d4000 rassstp rassstp.sys Sat Apr 11 00:46:40 2009 (49E020B0)
8fdd8000 8fe14000 rdbss rdbss.sys Sat Apr 11 00:14:26 2009 (49E01922)
8f7f7000 8f7ff000 RDPCDD RDPCDD.sys Sat Jan 19 01:01:08 2008 (47919224)
8a3f7000 8a3ff000 rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
827dc000 827ef000 rspndr rspndr.sys Sat Jan 19 00:55:03 2008 (479190B7)
9bea9000 9beb3000 secdrv secdrv.SYS Wed Sep 13 09:18:32 2006 (45080528)
8a224000 8a22e000 serenum serenum.sys Sat Jan 19 00:49:29 2008 (47918F69)
8a20a000 8a224000 serial serial.sys Sat Jan 19 00:49:34 2008 (47918F6E)
8fc90000 8fca4000 smb smb.sys Sat Apr 11 00:45:22 2009 (49E02062)
8fd68000 8fdd8000 SPBBCDrv SPBBCDrv.sys Thu Aug 28 18:10:06 2008 (48B7223E)
8a157000 8a15f000 spldr spldr.sys Thu Jun 21 20:29:17 2007 (467B17DD)
8ff4e000 8fffe000 spsys spsys.sys Tue Mar 10 13:10:28 2009 (49B69F04)
9bee6000 9bf2f000 SRTSP SRTSP.SYS Wed Nov 21 18:15:15 2007 (4744BC03)
8fd5e000 8fd67080 SRTSPX SRTSPX.SYS Wed Nov 21 18:17:28 2007 (4744BC88)
9bd7d000 9bdcb000 srv srv.sys Fri Dec 11 06:43:28 2009 (4B223060)
9bd56000 9bd7d000 srv2 srv2.sys Mon Sep 14 05:29:49 2009 (4AAE0D0D)
9bc7a000 9bc97000 srvnet srvnet.sys Fri Dec 11 06:43:10 2009 (4B22304E)
8f60b000 8f64c000 storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8f6e4000 8f6e5380 swenum swenum.sys Sat Jan 19 00:49:20 2008 (47918F60)
8fc6b000 8fc6cb00 SYMDNS SYMDNS.SYS Tue Feb 10 17:22:34 2009 (4991FE2A)
8fc2d000 8fc52000 SYMEVENT SYMEVENT.SYS Mon Aug 04 19:28:32 2008 (489790A0)
8fc7a000 8fc8ff00 SYMFW SYMFW.SYS Tue Feb 10 17:22:54 2009 (4991FE3E)
8fd34000 8fd3d000 SymIMv SymIMv.sys Tue Feb 10 17:25:25 2009 (4991FED5)
8fc6d000 8fc7a000 SYMNDISV SYMNDISV.SYS Tue Feb 10 17:24:58 2009 (4991FEBA)
8fc67000 8fc6ad00 SYMREDRV SYMREDRV.SYS Tue Feb 10 17:23:05 2009 (4991FE49)
8fc01000 8fc2c680 SYMTDI SYMTDI.SYS Tue Feb 10 17:22:31 2009 (4991FE27)
89ded000 89ed7000 tcpip tcpip.sys Thu Feb 18 06:28:54 2010 (4B7D2476)
9beb3000 9bebf000 tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
8f64c000 8f657000 TDI TDI.SYS Sat Jan 19 00:57:10 2008 (47919136)
827c6000 827dc000 tdx tdx.sys Sat Apr 11 00:45:56 2009 (49E02084)
8f6d4000 8f6e4000 termdd termdd.sys Sat Apr 11 00:51:14 2009 (49E021C2)
96a70000 96a79000 TSDDD TSDDD.dll unavailable (00000000)
8a1f0000 8a1fb000 tunnel tunnel.sys Thu Feb 18 06:28:13 2010 (4B7D244D)
8f6f0000 8f6fd000 umbus umbus.sys Sat Jan 19 00:53:40 2008 (47919064)
8a365000 8a366700 USBD USBD.SYS Sat Jan 19 00:53:17 2008 (4791904D)
8a29f000 8a2ae000 usbehci usbehci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8f6fd000 8f732000 usbhub usbhub.sys Sat Apr 11 00:43:14 2009 (49E01FE2)
8a257000 8a261000 usbohci usbohci.sys Sat Apr 11 00:42:52 2009 (49E01FCC)
8a261000 8a29f000 USBPORT USBPORT.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8fc52000 8fc67000 USBSTOR USBSTOR.SYS Sat Apr 11 00:42:55 2009 (49E01FCF)
8f7eb000 8f7f7000 vga vga.sys Sat Jan 19 00:52:06 2008 (47919006)
8a3d6000 8a3f7000 VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
826c9000 826d8000 volmgr volmgr.sys Sat Jan 19 00:49:51 2008 (47918F7F)
826d8000 82722000 volmgrx volmgrx.sys Sat Apr 11 00:39:25 2009 (49E01EFD)
8a11e000 8a157000 volsnap volsnap.sys Sat Apr 11 00:39:37 2009 (49E01F09)
8fd4b000 8fd5e000 wanarp wanarp.sys Sat Jan 19 00:56:31 2008 (4791910F)
8f5c7000 8f5d3000 watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
8a116000 8a11e000 wd wd.sys Sat Jan 19 00:52:18 2008 (47919012)
825b3000 8262f000 Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
8262f000 8263c000 WDFLDR WDFLDR.SYS Sat Jan 19 00:52:19 2008 (47919013)
96850000 96a52000 win32k win32k.sys unavailable (00000000)
8f5d3000 8f5dc000 wmiacpi wmiacpi.sys Sat Jan 19 00:32:47 2008 (47918B7F)
82682000 8268b000 WMILIB WMILIB.SYS Sat Jan 19 00:53:08 2008 (47919044)
9bed4000 9bee6000 WUDFPf WUDFPf.sys Sat Jan 19 00:52:49 2008 (47919031)
9bebf000 9bed3580 WUDFRd WUDFRd.sys Sat Jan 19 00:53:04 2008 (47919040)
Unloaded modules:
8fe1e000 8fe68000 IDSvix86.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
8a1d0000 8a1dd000 crashdmp.sys
Checksum: 00000000
8a1dd000 8a1e8000 dump_ataport
Checksum: 00000000
8a1e8000 8a1f0000 dump_atapi.s
Checksum: 00000000
You mentioned, in an earlier post, problems with Nvidia. Go to device manager. Look for any yellow markers indicating problems. If none, update the drivers for the graphic cards.
I will prepare a more detailed analyis. I thought that memory would solve this.
As to the BC124 steps:
"1) Ensure that none of the hardware components are overclocked. Hardware that is driven beyond its design specifications - by overclocking - can malfunction in unpredictable ways."
My system still doesn't recognize my monitor properly. I have an AOC LCD screen, yet windows lists it as a generic PnP monitor. It's been so since I bought the computer. I had to manually change the resolution to one larger than the PnP monitor would accept. Could the system interpret this as overclocked hardware?
