blue screen of death problem recurring
    Compaq Presario
    AMD Phenom-64 8750 (2.4GHz)
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Then you need to use Option One in the link to create it.
Ed
ok i finally did that... however i cant find where acpi.sys is in 7 zip in
\\.\E:\sources\boot.wim\1\Windows\System32\
am i doing something wrong??
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
It should be in the E:\sources\install.wim\3\Windows\System32\drivers\ folder (install.wim, not boot.wim). You show 1 as the number you used; isn't that the Windows Business folder? You have Home Premium, don't you?
Ed
    Home Grown Desktop
    Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz
    ASUS P5B-E
    3006 MB
    NVIDIA GeForce 8400 GS 512MB
    Motherboard - SoundMax
    ViewSonic VX2235wm / Dell 17" Generic PnP Anolog
    1680 x 1050 x 4294967296 colors / 1024 x 768
    3 x ST3250620AS 250GB SATA IDE 1 x WDC WD1200JD-00GBB0 120 GB SATA IDE
    Enerrmax 535W All-in-one SLI 20/24+6+
    Antec Sonata
    Antec 12cm SmartCool
    Logitech MX100 Laser
    Logitech LX710
    Bell Canada DSL 12MBps (supposedly)
    2 x HP Pavilion 9700v Laptops
Ed
i dont have a install.wim folder, only a boot.wim then i go into sources in e:/
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
Ed
well i found the acpi.sys in the drivers folder, thanks.. but.. that's in the boot.wim folder.. i will attach a printscreen to show you that i dont have a install.wim
as you can see in the printscreen, i am in e:/ where my recovery disc or whatever it is called is, and in sources but i only have boot.wim, nothing else
    Compaq Presario
    2814 MB ram
    NVIDIA Geforce 9400
    Generic PnP monitor
    1024 X 768
