Blue screen Error code 0000000a = "IRQL_NOT_LESS_OR_EQUAL
If you want to reinstall, you can use the DVD or the restoration partition, but I hate for you to do that. It seems that it is an easy problem to solve with memory. If you do want to try to reinstall, but that will not solve the problem if its memory, download Karens replicator, it make back ups easy. Just save to your external hard drive.
Karen's Replicator
I use Karens to back up once a week.
alright, if its memory, what should my next step be. Because memtest is not figuring it out, i have spent countless hours with that program testing this machine, and it has passed e verytime. And the BSOD can be quite random too, sometimes the computer works great and doesnt bsod forawhile. My concern is, say I take out a stick of ram, I have no way or really knowing if the computer is just not BSODing for the time being, or if the ram solved the problem. Cuz right now I have been in internet explorer for about 5 minutes, and all is well......... but its not going to last lol
ok perfect thanks, that is what I thought, I have backed up alot of peoples stuff before, but I just just back up there entire user profile folder, as that is where all there documents and pics, music is saved, just thought that there maybe a better way! Thanks for your help, appreciated. i will levae this open and report back when I reformat.
I do wish you luck, I think that you know that, but I am afraid it may be memory and then it still will not work.
